81' KZ1100 TRANNY HELP WILL NOT SHIFT UP
- Tedster
17 Jun 2009 19:12 #300028
by Tedster
81' KZ1100 TRANNY HELP WILL NOT SHIFT UP was created by Tedster
Hello
i am new to the forum this is my first post,
i picked up a clean stock 81' kz1100 pulled the carbs off to clean them and to rebuild themput a new agm battery in it got good compression all cylinders are between 118 and 122 now the bad the tranny will shift into first and back to neutral but will not go into 2,3,4,or 5th i pulled the side cover off and cannot see anything wrong visually,has this ever happened to anyone with this paticular bike,this is reall frustrating i haven't even give it a good bath yet this thing is in really good shape always kept inside i sure hope the motor don't need to be split:unsure:
anyone got any idea's any help will be appreciated
thanks Ted
thanks Ted
- Thank you received: 2098
17 Jun 2009 19:27 - 17 Jun 2009 19:28 #300037
by Patton
Replied by Patton on topic 81' KZ1100 TRANNY HELP WILL NOT SHIFT UP
Hello, Ted, and WELCOME to KZR!
We're glad you're here!
Bike likely has a safety-convenience feature whereby transmission won't shift above neutral unless the rear wheel is rolling (or turning) forward.
Give it a try while the rear wheel is rotating forward, and hopefully snick right into 2nd gear.
Good Luck!
Good Luck!
Last edit: 17 Jun 2009 19:28 by Patton.
- gane
- Thank you received: 1
17 Jun 2009 19:37 #300046
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic 81' KZ1100 TRANNY HELP WILL NOT SHIFT UP
Ted, Not intimate w/ the 11, but on earlier zed,s there exists a peculuar mechaniszm within the countershaft which requires motion at speed to engage 2nd & upper gears. In essence, centrifical force causes ball bearings to force gears into relitive positions. before going back in, try, bringing eng to temp, elevate rear wheel, and w/tire spinning attempt up-shifts. ope this helps. G
- Tedster
17 Jun 2009 19:43 #300051
by Tedster
Replied by Tedster on topic 81' KZ1100 TRANNY HELP WILL NOT SHIFT UP
thanks guys
i will try moving the bike forward and trying it i can't warm the bike up because i have the carbs off
ted
ted
- timebomb33
- Thank you received: 10
17 Jun 2009 19:45 - 17 Jun 2009 19:54 #300052
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic 81' KZ1100 TRANNY HELP WILL NOT SHIFT UP
the bike has to be moving in order to get it into second gear. don't freak out its normal.
Last edit: 17 Jun 2009 19:54 by timebomb33.
17 Jun 2009 19:53 #300058
by Patton
If on the center stand, just spin the rear wheel forward by hand, and while its still rotating, shift into 2nd gear.
Okay for engine to be cold.
If center stand not available, may just sit astride the bike, roll bike forward (or get a helping push), and while moving forward, shift into second gear.
The design makes it easy to find neutral when the bike is stationary. And undertaking normal first gear start off.
Good Luck!
Good Luck!
- Tedster
17 Jun 2009 20:47 #300073
by Tedster
thanks alot for the quick replys i am liking this site a whole lot already,i tried to turn the tire and shift up no go there i am really not that concerned about it after the replys about the safety device,i need to get the carbs rebuilt and back on the bike i will let everyone know how it goes,
thanks ted
thanks ted
- donthekawguy
- Thank you received: 8
17 Jun 2009 23:23 #300136
by donthekawguy
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
Replied by donthekawguy on topic 81' KZ1100 TRANNY HELP WILL NOT SHIFT UP
That compression seems a little low. You might want to set the valves and see if it improves. I think it shoul dbe in the 140 to 150 range.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
