Stuck oil pan
- DMR
1980 KZ650
-Vance and Hines exhaust
Duluth, MN
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- DMR
1980 KZ650
Duluth, MN
- Bluemeanie
- Thank you received: 14
- telefunkin
- bountyhunter
- Thank you received: 337
- DMR
Pocket knife blade tapped into the gap gently at the corners.
I'll give this a try tomorrow and see how it goes.
1980 KZ650
Duluth, MN
- DMR
I took all 15 bolts out, is there anything I'm missing? There is absolutely no movement in the pan, it feels like it's still bolted on. Are there any good products that I can buy that I can spray on and let it penetrate the adhesive so I can get this thing off?
1980 KZ650
Duluth, MN
- timebomb33
- timebomb33
- DMR
do you have a deadblow hammer or a copper/brass hammer if so give it sideways if not use a piece of wood and smack it with a regular hammer it should shock it loose
This is what I ended up doing and it finally popped off.
Thanks for the suggestions.
1980 KZ650
Duluth, MN
- MFolks
- Thank you received: 540
