Just broke a ring!!!!!
- BARNEYHYPHEN
10 Mar 2006 16:58
Took a couple of hours off work this afternoon to get the engine back together. Just come in cause the weekend has just ended at Friday 6:30pm Central. BROKE A RING. BK pistons & rings 70.25mm from Australia. AHHHHHHHHHHHH!
- wireman
Re: Just broke a ring!!!!!
10 Mar 2006 17:53
there seems to be a lot of ring prblems with that particular motor.
- BARNEYHYPHEN
11 Mar 2006 16:09
Wire, Wish I could blame it on the motor but I'm affraid stupidity and trying to get things done too quickly are the problems.
- wireman
11 Mar 2006 16:33
did you get anymore extras from that guy who sent you the last one?
- BARNEYHYPHEN
13 Mar 2006 08:49
He certainly has some and I should hear this morning how many he has and how much he wants for them. I told him two oil rings and 2 center rings would be perfect if he'ws got them. That should allow me to destroy a couple more!
- gas
13 Mar 2006 09:12
Don't be so hard on yourself buddy. I've never done what you are doing. Atleast you have the stones to roll up your sleeves and dive in. I try to be very carefull but still make mistakes also. I don't mind if the mistake is not too expensive and I learned something in the process. Most of us don't have a factory mechanic standing beside us, pouring coffee and massaging our necks during our bike work. It's all good.
- BARNEYHYPHEN
13 Mar 2006 09:37
Thanks Gas. Appreciate the kind words. Still pains me when I do these things. My problem is impatience, trying to get the job done too quickly.
- wiredgeorge
13 Mar 2006 10:53
BH - Nobody is born with patience and patience isn't a normal human characteristic. Patience is learned during trying times as is character. We admire these traits in others but no one wants to go through the fire themself. Keep plugging away, you have come miles since joining the board. God bless.
- BARNEYHYPHEN
13 Mar 2006 10:59
Thanks WG. I'll let you know when it's all buttoned up.
- wireman
13 Mar 2006 12:06
take it from the guy who got really impatient,drunk,mad and spent 2-3 hours trying to figure out why a motor wouldnt come out the wrong side of a frame it happens!:woohoo: i saw an ace shade tree ford mechanic put a 390 ford together and stuff it in the car,sounded good till the rod bolt/nut he forgot to torque came loose:S make sure to double check everything!
goodluck,happy wrenching!
- BARNEYHYPHEN
13 Mar 2006 12:28
Actually got real "lucky" when the ring broke, wouldn't you know it, the 1" bit of ring fell right down into the crankcase! Couldn't see it of course. Tried to magnet it out, that didn't work. So I took the pan off. Real treasuretrove that turned out to be...all sorts of "stuff" down there! Some other misc' ring bits, piston fragments and, best of all, a "spare" on of those small two hole plates that goes on the top cam idler tower. Needed one of those. I nearly found myself enough stuff in there to build me another engine. Lots o' crap.
Seriously though, it did give me a good oportunity to clean the pan and replace a bit or two in the oil pump. I've left the pan off for now until I've got the top buttoned up. That should guarantee I won't do it again.
- Z1109R Fin
13 Mar 2006 23:41
Yeah, well s..t happens. Week ago on a nice sunday me and my bro started to build up the top of my engine. This wasn´t the first time either...
Everything went smoothly, all rings on #2 and 3 piston went in nicely, #4 went in smoothly and at the same time #1 seemed to go in nicely. I just tapped the block down with my hand and it stuck! It just didn´t move at all. I had to take a small piece of wood and a hammer to tap the #1 piston back down and out from the sleeve. Lower oil ring was bent between the piston and sleeve!!! OK, this time it didn´t do any actual damage to the bore, small marks could be seen but luckily they were so low that it didn´t matter. Just new oil rings and back tio work. So ya see it happens. It´s not always your fault.
Z1000R ´83...Slightly modified...
