Sprocket cover questions!
- BradP77
15 Jun 2009 18:33 - 15 Jun 2009 18:53 #299474
by BradP77
Sprocket cover questions! was created by BradP77
I am having to replace my sprocket cover because my sprocket came off and knocked a chunk out of mine (can't believe that happened). I torqued the sprocket nut to 100 ft lbs and used red thread locker, so hopefully it'll stay on this time. I bought a cover on eBay, but when I received it, I noticed that it looks a lot different on the back side (see photo). Apparently it is from an older model. Is the stuff that sits to the rear of the clutch release remnants of a chain oil pump? The cover seems to bolt up fine to my '77 KZ1000LTD. Will that extra stuff cause any problems? What is the purpose of the foam and mesh guard that was screwed to the inside of the '77 sprocket cover (and can't be attached to the older one)? Lastly, if I install the sprocket guard (photo lower right) that I found, will that prevent this from happening again? Thanks to all the bike gurus for helping this novice out.
Last edit: 15 Jun 2009 18:53 by BradP77. Reason: photo file size too big
- PLUMMEN
- Thank you received: 104
15 Jun 2009 18:52 #299478
by PLUMMEN
Replied by PLUMMEN on topic Sprocket cover questions!
might of been part of the chain oiler from a z1
- BradP77
15 Jun 2009 18:57 #299480
by BradP77
Replied by BradP77 on topic Sprocket cover questions!
- Old Man Rock
- Thank you received: 225
15 Jun 2009 19:33 #299489
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Sprocket cover questions!
... Yupper!chain oiler
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Thank you received: 2098
15 Jun 2009 19:53 - 15 Jun 2009 19:59 #299494
by Patton
Replied by Patton on topic Sprocket cover questions!
BradP77 wrote:
The foam and mesh guard is supposed to help reduce engine noise.
Imo, the sprocket guard won't do much toward preventing damages resulting from a sprocket nut coming loose. Because it's thin and gets chewed up quickly. Frequently, it's not re-installed, but I prefer having it in place for whatever purpose MaKaw intended.
I believe the sprocket guard was no longer fitted beginning with the 1977 KZ1000 which started using the foam and mesh guard. And am uncertain whether there's enough room for the sprocket guard under the later cover with foam and mesh guard remaining in place.
Am wondering whether the KZ1000 mission cover still has the same three threaded holes for the screws attaching the sprocket cover.
Good Luck!
...What is the purpose of the foam and mesh guard that was screwed to the inside of the '77 sprocket cover (and can't be attached to the older one)? Lastly, if I install the sprocket guard (photo lower right) that I found, will that prevent this from happening again?....
Good Luck!
Last edit: 15 Jun 2009 19:59 by Patton.
- BradP77
15 Jun 2009 20:24 #299506
by BradP77
Yes, the 3 holes for the sprocket guard are still there on my '77.
- MFolks
- Thank you received: 540
15 Jun 2009 20:45 #299509
by MFolks
Replied by MFolks on topic Sprocket cover questions!
As long as you have it apart,clean,inspect, and re-grease the clutch actuation mechanism. Check the lingage where the clutch cable for excess play.
