- Thank you received: 2
I know it's a long shot...modern clutch lever?
- caffcruiser
15 Jun 2009 17:57 #299458
by caffcruiser
I know it's a long shot...modern clutch lever? was created by caffcruiser
Anyone running one?
I have a 03 GSXR clutch lever and perch and my clutch cable is too short.
Anyone have info on what length cable to run?
- timebomb33
- Thank you received: 10
15 Jun 2009 20:12 #299501
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic I know it's a long shot...modern clutch lever?
have you backed the adjusters all the way off it should fit if you do that also try taking the lever off and then installing the cable sometimes that will work.
- caffcruiser
15 Jun 2009 21:15 #299513
by caffcruiser
Replied by caffcruiser on topic I know it's a long shot...modern clutch lever?
Cable is installed, but it's short enough that it took some pressure to get it installed, and I can't actually pull it.
In essence, it's as if the clutch is pulled in all the time.
- Thank you received: 2098
15 Jun 2009 22:02 #299529
by Patton
Replied by Patton on topic I know it's a long shot...modern clutch lever?
caffcruiser wrote:
Sounds like Suzy lever assembly needs more inner cable exposure relative to sheath length.
Might be able to resolve by shortening sheath to achieve additional inner cable exposure, provided resulting sheath length is sufficient for routing.
Could resort to custom cable, which requires precise dimensions for sheath length (basic routing) and exposed inner cable length (as required by the particular assembly design).
Good Luck!
Good Luck!
