- Thank you received: 104
Big Blocks - Leakers?
- PLUMMEN
14 Jun 2009 21:36 #299278
by PLUMMEN
Replied by PLUMMEN on topic Big Blocks - Leakers?
the bag for my handtools i keep in my service van weighs about 75 lbs im guessing,i normally just grab what i need out of it when im doing service calls.but since im gonna be far from home im loading for bear,otherwise there will always be one tool i need that sitting back in nebraska! :laugh:
- APE Jay
- Banned
- Thank you received: 58
14 Jun 2009 21:59 #299289
by APE Jay
Replied by APE Jay on topic Big Blocks - Leakers?
supercharged wrote:
Yes. All of you come out here to Willow.
Jay
If you get down south while out here... give me a shout! Would be nice to meet you... I know there are several others here in the SoCal area, too.
And if you want to turn a wrench... I'm up for it;)
Jay
- PLUMMEN
14 Jun 2009 23:33 #299304
by PLUMMEN
can we set up a tour of the shop JAY ?
- StreetfighterKz
- Thank you received: 117
15 Jun 2009 04:51 #299328
by StreetfighterKz
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
Replied by StreetfighterKz on topic Big Blocks - Leakers?
If you take a look at Dragbike.com's forums there are posts on how to keep them from leaking as bad. On solution involves using thin walled copper tubing and sleeving some of the head stud holes. Another was making a small metal flap that bolts to the front chain guide in the block and overlaps the cam chain galley into the head.
Later, Doug
Later, Doug
1989 Vmax
- bowtie39
15 Jun 2009 15:57 #299423
by bowtie39
Replied by bowtie39 on topic Big Blocks - Leakers?
From what area do these seep from. Have a 1000 LTD that is leaking from the valve cover best I can tell. I was just going to replace the gasket and cam plugs but not so sure now.
Roger
Roger
- supercharged
15 Jun 2009 21:46 #299526
by supercharged
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport......
Replied by supercharged on topic Big Blocks - Leakers?
Standard engine - most common is the tach cable seal at the engine. Valve covers could, but I have never had any... and of course check torque on the head itself.
Big blocks... at least mine, is seeping from the head gasket. in 1 or 2 spots
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
