78 KZ650 C2 flat spot and stumbling
- cw28147
12 Jun 2009 17:35
Ok, the bike is running and I have been riding it, but I have noticed one thing that irritates the crap out of me. I was hoping that anyone on here could provide some insight.
The bike will run just fine at idle, and will pick up and go ok, but there is a notable "flat spot" where the bike just does not want to perform. This is around 50-60 miles per hour, or slower depending on which gear I am in. This is all guess work, since there is no tach or speedo on the bike. Yes, the carbs were cleaned and new gaskets, float and needle installed. The main jet is a 110 and the pilot jet, I really have no idea.
The flat spot seems to run at certain throttle percentage, get it past there, and the bike functions perfectly, but get it in the range, and it spits, stumble and misses.
Now, I know the next set of questions... What about the rest of the setup goes something like this. Pod filters, four into two aftermarket exhaust (Fully open/no baffles), and I am located in the Piedmont (southern central) area of North Carolina (approx 800 ft elevation).
Anyone have any ideas on what I can do to remedy this?
Just a car mechanic trying to figure out his way around old bikes... After all, it is just nuts and bolts right???
- spudbudy
- Kick it like you mean it
Re: 78 KZ650 C2 flat spot and stumbling
13 Jun 2009 10:32
had a similar issue with my bike change the needle clip position should help. what size carbs do you have? pods are hard to jet for I would try and airbox myself if you have one available. was a day and night difference for me. good luck. you want to lower the needle clip position stock position is #3 try #4 see if that helps. good luck
78 KZ 650B2. Vetter faring, Dyna S, Dyna Green coils, WG coil mod,AGM Battery, VM26SS carbs, Pilot jet 15, mains 110, jet clip #2 shimmed position, Modified stock air box, stock air filter, Kerker 4 into 1 with stock baffle. currently 48,785 miles.
and climbing daily.
- rstnick
13 Jun 2009 10:33
I'd check your points (if your bike still has them) for pitting/gap/cleanlyness.
My C2 also had somewhat of a flat spot similar to yours, although not with the "spits, stumble and misses".
I contributed it to the points set up as I had not done any mainteneance on them in a few years, and having switched to an electronic ignition, the flat spot was gone and the engine had power all the way up the rev range.
"spits, stumble and misses" does sound fuel related though. Or just not the right fuel/air mix.
Look for leaks in the carb manifolds. Maybe you got air seeping in somewhere.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- cw28147
14 Jun 2009 04:21 - 14 Jun 2009 04:29
OK, stock air box is out of the question at the moment since the original was lost in the fire. P.O. tried rebuilding the carbs and rewiring a few things, and managed to burn most of the bikes plastic parts off. As for the carbs, they are the stock carbs, just rejetted. Will have to try the needle clip adjustment. The points are brand new, installed them before putting it on the road. checked the spark with a spark tester and I have great spark through all ranges. So it looks like this is a fuel/air problem.
Gentlemen, I do appreciate your assistance in this.
Last edit: 14 Jun 2009 04:29 by cw28147. Reason: needed to add
