- Thank you received: 5
Ticking in the 810!!!!
- jordan
I checked compression and it was good in all 4. WOuldnt i be losing compression if i had a bent valve. Also, the bike seems to run about the same, doesnt pop, backfire, or anything.
ANy help would be appreciated.
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- sabell
'78 KZ1000A2
'79 650SR
- Old Man Rock
- Thank you received: 225
I'm having an issue when running hot, really running the rpms up on the HWY in triple digit weather for 20 miles or so I get this squishing sound in a chamber...
I know, weird and no other way to describe it. Several other members were sent a video clip where I was actually able to record it... they can't figure it out either, not a tick, more a squish...
Anyhow, I originally thought it was in the upper head/valve until I got me a stethoscope... Well, I was wrong for I traced it all the way down to the oil pump!
sonsabitch!
The sound is traveling up through the case/cylinder/timing chain slots up into the valve cover and resonating (being amplified)...
Anyhow, exhaust tick is pretty distinctive and easily found, not necessarily fixed mind but you but isolated to where it's at rather easily.
Jordan, spend the $4 and you won't be sorry. You may be surprised where the originating source actually is coming from... Comes with an 18" extension to get down deep...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
A compression test is only a measure, of how much air the motor is pumping. A slightly bent valve, can sometimes still pump air.
A leak down test, will tell the cylinders ability to hold air. If it is bent, it will leak air.
Should I say "take your time, you have a lot invested" It's funny, there are no books are info, on what to do after you start it........
PS- I would exspect the valve train to move around alittle, after a new motor and being hammered on, at the track. The valves should be checked alot, until the motor is broken-in.
- jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- PLUMMEN
- Thank you received: 104
- jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- kzz1p
k, i will check them soon. Not questioning this at all, just was wondering what i should be looking for. If valve clearances are off, what would cause the ticking.
That tick could be a loose, bucket to cam lobe clearance. Look for tight ones, as the motor gets some wear on it.
- PLUMMEN
- timebomb33
I THINK MY POWERBAND BROKE
- jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
