81 kz550 ltd- wont stay running
- hmmmgood
12 Jun 2009 14:06 #298634
by hmmmgood
81 kz550 ltd- wont stay running was created by hmmmgood
Hey boys. I need some help. its my first bike and I love getting dirty fixing it up but i have come to a wall!! Its runs but wont stay running. It starts with full choke, and revs up to around 3000rpms but when i crack the choke it dies... Any suggestions ? Please
- telefunkin
12 Jun 2009 17:31 - 12 Jun 2009 17:32 #298679
by telefunkin
Replied by telefunkin on topic 81 kz550 ltd- wont stay running
Are all cylinders firing? I beleive that is a four so rev it up for a minute and check if all pipes are getting hot, be careful tho, they get really hot really fast.
If not then you will need to check for spark and if you have that then move on to a compression test. Check for airleaks around the carb boots and carbs.
Also, you didn't mention if the carbs were cleaned or not. If the bike sat for any length of time then it should be cleaned thoroughly.
Last edit: 12 Jun 2009 17:32 by telefunkin.
- MFolks
- Thank you received: 540
12 Jun 2009 18:36 #298699
by MFolks
Replied by MFolks on topic 81 kz550 ltd- wont stay running
Get a spray bottle full of water,it's better than touching the pipes and getting burned when checking which cylinder is running. Water flashes to steam at 212 F.
- OKC_Kent
- Thank you received: 20
12 Jun 2009 19:19 - 12 Jun 2009 19:25 #298720
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic 81 kz550 ltd- wont stay running
How long have you had her, and has she ever run smooth? I would go into the carbs and make sure the jets are clean and float level is right, and also the petcock, make sure the fuel flows.
Also make sure all the other stuff is right, like a clean air filter and airbox, new sparkplugs, etc
Oklahoma City, OK
Last edit: 12 Jun 2009 19:25 by OKC_Kent.
- hmmmgood
12 Jun 2009 19:43 #298726
by hmmmgood
Replied by hmmmgood on topic 81 kz550 ltd- wont stay running
I just got her and she didnt run. Cleaned the carbs tho and changed the spark plugs. Thanks for the help! Keep it coming! Im new at this
- timebomb33
- Thank you received: 10
12 Jun 2009 19:51 #298729
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic 81 kz550 ltd- wont stay running
it sounds to me like you missed the pilot circuits when you cleaned your carbs you will have to go in and do it again they will be plugged pull the pilot jets and try to get them clear then attack the actual passages themselfs.
- telefunkin
12 Jun 2009 21:04 #298737
by telefunkin
hmmmgood wrote:
How long was she sitting before you picked it up?
You should definately check the timing advancer to make sure it is not stuck open.
