82 KZ1000 LTD engine serial numbers
  • bhanse
  • bhanse's Avatar Topic Author
11 Jun 2009 15:30
#298463
I went into the archives to check on the begining and ending engine ser.no.for my bike....the serial numbers for the 82 LTD go from KZT00JE019201 to 034189. So my engine should fall between these numbers....it doesn't...the serial number on my bike is 034231...so this engine falls after end of model year....Now I found the 82 STD (J2) engine numbers start at 019201 and end at 039300....would it be safe to say I have a 82 J2 engine in my LTD?....the bike was "put" together with a mixture of parts as the swingarm is from a 80 or earlier KZ with the 4 needle bearings and the "zert" fitting....so could someone inform me where I might be wrong and do have an 82 LTD engine?....btw I bought the bike this way....with NO info....just hit and miss on the parts.....bruceB)
82 KZ1000 LTD
  • Mcdroid
  • Mcdroid's Avatar
  • Away
  • Gone Kwackers
Re: 82 KZ1000 LTD engine serial numbers
11 Jun 2009 16:46
#298473
Double check the engine VIN series on www.zedder.com to confirm your conclusions.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • bhanse
11 Jun 2009 18:59
#298497
I did that before I posted and they're the same as the archives.....all I would like to know is what engine I have in this bike as info for the next owner (if I sell it)
82 KZ1000 LTD
  • bhanse
11 Jun 2009 19:02
#298499
I went through the vins to insure I had a K2.....which I do ....even went through Kawasaki's site to conferm the vin
82 KZ1000 LTD
  • Mcdroid
  • Mcdroid's Avatar
  • Away
  • Gone Kwackers
12 Jun 2009 03:04
#298544
I think I get what you are asking...you know your motor has been replaced, what style bike did it come from? Correct? Kawasaki had a tendency to use the same type of motor in a number of simultaneously produced bikes. For example, the 750(four) series early '80's (LTD, GPz (also ZX GPz's), Standard, etc.) all drew from the same series of motor numbers (the heads might be different, but the motors were fundamentally the same). It was no different with the 998cc KZ series...the M, K, J, and P bikes all drew from the same motor series and you cannot tell from a motor VIN which style bike the motor is associated with. So, to answer your original question, the replacement motor might have come from a J2, but it definitely came from a J engine series bike. BTW, the entire 998cc motor series is termed 'J' motor...but the 'J' bike was only the J1/2/3 standard.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
