- Thank you received: 1
Suggested plug gap with Dyna S
- BARNEYHYPHEN
BH
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- BARNEYHYPHEN
Not knowing as much as I should about the relationship between ohms, volts, amps etc, are you able to run a 50 thou gap because your running 2.2 ohm coils? Is a 2.2 ohm coil capable of putting out a higher voltage than a 3 ohm coil, assuming the same voltage input?
There's obviously a corrallation between the voltage output of the coils and the gap used but is there some rule of thumb? Say upto 30,000v, don't use a gap larger than 30 thou? Can 1000v jump 1 thou? Is there anything linear about this relationship between volts and gap?
Thanks.
BH
- nads.com
- Thank you received: 20
- bountyhunter
- Thank you received: 337
There is a relationship but it's not simple. I depends on altitude, humidity and pressure as I recall. The spark also jumps easier depending on what ions are in the gas.Otakar, thanks for the input. I'm running a Dyna S with 3 ohm coils.
Thanks.
BH
Back when I built HV power supplies, the rule of thumb was to use 0.1" air gap per thousand volts to PREVENT a spark jump at sea level. At higher altitudes, the sparks jump a lot more easily.
I think a typical plug with an .032" gap will probably fire in the 5 - 10 kV neighborhood, that's a guess.
FYI: I am not convinced widening the gap and forcing the coil's secondary winding to a higher voltage improves performance, but it does increase voltage stress on the coil winding. I think any decent spark is going to work. If you are standing in a room filled with gasoline vapor, it probably won't matter whether you strike a match or ignite a road flare.... same result.
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
With an electronic ignition, the coils have a longer charging time, therefore more spark and can use either gap. Most people when using super high compression, go for the short fat spark. There is less chance of the spark being blown out with a shorter distance to travel.
I have used wide and narrow plug gaps in the Z motor. Now days I try to find some middle ground (.030"-.040"), I have found no real differance. I have went as high as .055" with the Dyna and Martex. I perfer .030"-.032" with a Mag.
Perhaps the results would be better noticed if you used the whole nine yards, side gaping, plug indexing, two plugs per cylinder, various plug gaps, diff heat ranges,
etc.
Every motor is different, you just have to play with it. I guess for me, it's just peice of mind.
- BARNEYHYPHEN
BH
