Tach Gear
  • jimyed
  • jimyed's Avatar Topic Author
Tach Gear
10 Mar 2006 08:00
#29839
I am having problems removing the Tach Gear from my head. I has come part way but will go no farther. :(
Is there a trick?:unsure:
  • cudaosix
  • cudaosix's Avatar
Re: Tach Gear
10 Mar 2006 08:44
#29848
It was a tight fit on my 1000 too for some reason. The way I removed it was with a vice grip and patiently worked it out. Place a piece of material over it to keep the teeth on the vice grip from chewing it up. Once out you can sand down the tach gear with light sand paper so that its much easier to put back in but with some resistence when its almost in completly. Worked well for me, easy to do. Another member was able to pickout the seal and pop a new one back in actually without removing anything.
Post edited by: cudaosix, at: 2006/03/10 11:46
  • koolaid_kid
  • koolaid_kid's Avatar
Re: Tach Gear
10 Mar 2006 09:38
#29860
p.m. sent.
kk
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
