valve seating giving me no compression?
- kylevk
10 Jun 2009 21:19 #298206
by kylevk
valve seating giving me no compression? was created by kylevk
hey all,
just picked up a non running 82 kz750 ltd....i knew it would need carb work and that was all. after doing a compression test i found no compression unless i put my hand over the carb i could get a little. the cylinders seem smooth/clean, the pistons look decent and the piston rings also seem ok. what i'm thinking is that whoever had it before me tried to do carb work on it but did not sync them after. which caused carbon build up on the valves so that they do not seat properly.this would go along with the fact that i could get compression if i cover the carb. i'm far from a mechanic which is why i have this project but i'm wondering if this makes sense? when the valves are closed should they be sitting flush with the face? any help or guesses of what to check would be awesome.
thanks,
kyle
thanks,
kyle
- bountyhunter
- Thank you received: 337
10 Jun 2009 21:54 - 10 Jun 2009 21:54 #298213
by bountyhunter
Replied by bountyhunter on topic valve seating giving me no compression?
Either your valves are not seating tight or the camshaft timing is wrong. You should check valve clearance.
Last edit: 10 Jun 2009 21:54 by bountyhunter.
- timebomb33
- Thank you received: 10
10 Jun 2009 22:00 #298227
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic valve seating giving me no compression?
if the valves aren't sitting flush with the seats then it sounds to me like you have some bent valves carb sync would in no way cause the problem your talking about it either has had the cam's installed incorrectly and they have made contact with each other or with the pistons or the timing chain has jumped somehow. or a tensioner has broken or worn out badly enough to cause excess play in the cam chain causing it to jump that would be a very extreme case but it could be possible.
- bountyhunter
10 Jun 2009 22:07 #298239
by bountyhunter
kylevk wrote:
On my 750, when the valve guide seals go bad, the oil trailing down coats the seats and the oil residue burns on and (over time) keeps them from closing fully.hey all,
- kylevk
11 Jun 2009 07:41 #298316
by kylevk
Replied by kylevk on topic valve seating giving me no compression?
i dont think its bent valves, they sit flat, but theres a lot of build up so its possible that they might not get a good seal.
- BSKZ650
- Thank you received: 14
12 Jun 2009 05:21 #298553
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic valve seating giving me no compression?
I have seen a lot of build up on valves over the years but it never stops them from seating, if you have the head off, pour some light fluid like slovent in the ports with the valves closed ( head standing on side ) if the slovent runs out, they are not seating and will need to come out to see what is wrong
