- Thank you received: 28
Plug reading...
- TeK9iNe
- What did you do!?!
10 Jun 2009 12:42 #298043
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Plug reading... was created by TeK9iNe
How long, at a given throttle position, do you have to hold it there to get a proper plug reading?
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Kawickrice
- Thank you received: 18
10 Jun 2009 13:17 #298051
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic Plug reading...
Do a search for "plug chop" also look through the filebase. There have been numerous threads on this topic. That should get you going in the right direction.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- davel
10 Jun 2009 20:02 #298188
by davel
Replied by davel on topic Plug reading...
TeK9iNe wrote:
WOT for 1/4 mile should be sufficient. Cut the kill switch and pull in the clutch.
Start with fresh plugs and ensure the engine is up to temperature.
refer to the following: www.empirenet.com/pkelley2/sparkplugreading.html
This method of plug reading should also work for mixture readings at part throttle but heat range should be tested at WOT.
- TeK9iNe
10 Jun 2009 20:23 #298198
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Plug reading...
Thx man.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
