Need help fast!!!! plug threads
09 Jun 2009 20:02 - 09 Jun 2009 20:18 #297869 by jordan
Need help fast!!!! plug threads was created by jordan
Alright, i was messing with the timing and my dyna s 2000 on my 810. I pulled the plugs to rotate the crank (all came out nicely), and after i was done i started putting the plugs back in. The #2 plug threaded a couple times and stopped, so i turned it a bit, and it was just getting harder to thread. I immediately stopped to prevent stripping the threads. I noticed that there was a small bit of metal shaving that came out with the plug. Looked in the hole with a flashlight, and noticed the first few threads were shiny like they were being stripped. The majority of the threads from the inside up are fine, and untouched. Is there any way i can clean up the threads without pulling the head? Like a tap or something? I need it running asap, any help would be appreciated
Has anybody used a spark plug thread chaser successfully?
Just coat the chaser with grease to try and catch any shavings?
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
Last edit: 09 Jun 2009 20:18 by jordan.
09 Jun 2009 20:27 #297884 by Silver Tiger
Replied by Silver Tiger on topic Need help fast!!!! plug threads
when i got my z1 there were freakn heli coils in all the plug holes 3 came out with a compression test! i have a new head now i would recomend to go to kunkles auto or a machine shop and see if u can get a tap it kit for the threads. they should sell one to fit the sparkplug u bring in. i would use clean axel grease around the threads to stop shavings from getting in the head and only go a quarter of a turn at a time to get all the shavings out. that should help get the threads straight again
Bikes Owned
1972 Rickman 250 Montesa
1974 Z1 - Kz1000 Jug 1045cc 10.25:1,Port and polished,Oversized valves,Underbucket shims,36mm Mikuni RS Flatslides,Dyna 2000 and 2.2ohm coils, Webcams 435 @ 288° duration,Taylor wires,NGK iridium plugs
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
09 Jun 2009 20:29 #297886 by Patton
Replied by Patton on topic Need help fast!!!! plug threads
Imo best to use a "reverse plug tap" tool which retaps beginning from the DEEP end, thereby starting with the good threads and then continuing on up and out.
Not cheap, but cost is offset by time and parts needed to r&r head.
Good Luck! :)
09 Jun 2009 20:34 #297890 by jordan
Replied by jordan on topic Need help fast!!!! plug threads
Good Luck! :)
That sounds like the perfect tool patton, i have never heard of one. How would you get a tool into the spark plug hole to clean out the inside threads first?
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
09 Jun 2009 20:52 #297901 by Patton
It goes inside and then expands. Will try to find a link to source and price.
Attempting to precisely start an ordinary tap or thread chaser from the top and have it dovetail perfectly into the good threads would imo be futile and only increase the damage. Am thinking most would concur with this prognosis.
Am thinking The Gringo has reported successfully using the tool.
Good Luck! :)
09 Jun 2009 21:02 #297907 by Patton
Click here > Reverse plug tap
There are probably other sources also, such as maybe "Snap-On" or other major tool suppliers or outlets.
Good Luck! :)
09 Jun 2009 21:08 #297911 by jordan
Thanks for finding that. Maybe a shop in town has the tool, but i can probably buy the tool for what they will charge to fix it. I was hoping to get it to a car and bike show this weekend, but may have to sit for a while now.
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
10 Jun 2009 16:23 #298093 by timebomb33
Replied by timebomb33 on topic Need help fast!!!! plug threads
if you can't find one of those rev erse plug taps just go and get a thread chaser they work well to i have one in my track tool boxes just for emergency's
I THINK MY POWERBAND BROKE
10 Jun 2009 16:39 #298097 by jordan
Well, after work i searched town and nobody had a back-tap on hand so i ended up getting a thread chaser. I was very careful, and coated the chaser with oil before tapping. Turned rough right away, but after about a second it threaded right into the existing threads. Good as new. Ran it in another time jsut to make it nice and clean. Thanks for all the fast help everyone.
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • The Gringo
  • ¡Usted no necesita otra motocicleta!
10 Jun 2009 16:42 #298098 by The Gringo
Replied by The Gringo on topic Need help fast!!!! plug threads
Yep I bought one about a year ago and used it on 2 bikes where the PO had boogered up the threads a bit. The tool works slicker than snot on a doorknob. I bought mine from here.
www.northerntool.com/webapp/wcs/stores/s..._200353676_200353676
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
