Need some help with exhaust
09 Jun 2009 18:40 #297822 by Hayden1977
Need some help with exhaust was created by Hayden1977
I am newly registered although I have breezed through several times over the years. I am resurrecting a 78 Z1r that hasn't seen the road in maybe 15 years or more. I recently refitted the aftermarket sidewinder exhaust after having the bike apart for some time. I clearly didn't understand how the two clamshells work with the pipe collar to seal the exhaust because I think all four pipe are leaking. I replaced all of the gaskets with new and stuck them in place with a little grease. I then put the clamshells over each pipe and slid the collar over the clamshells. I snugged everything up and tapped each head pipe with a rubber mallet to check for metal to metal contact. Finally I put a final torque on the collars. I used new bolts and lock washers. Did I put the clamshells in wrong?
I am also hoping to replace this exhaust soon with something new. The Kerker is a little rich for my blood. The parts unlimited catalog says the vance and hines pro pipes require chassis modificaton. Does anyone know exactly what they are talking about? All exhaust recommendations are welcomed.
Thanks.
09 Jun 2009 18:46 #297826 by otakar
Replied by otakar on topic Need some help with exhaust
I personally love the Mack pipe which you can also buy from BikeBandit. The canister pipe sounds much better than the megaphone pipe. Mack makes both. Always mount the header pipe with the tail pipe removed. this assures the pipe sitting flat on the washers.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
09 Jun 2009 19:14 #297841 by edspring1
Replied by edspring1 on topic Need some help with exhaust
Its a crazy design but it works [most of the time]
The clam shells have the straight edge on one end, and the bent/raised edge on the other end. The straight edge goes towards the head but stays on the pipe itself, and the collar pushes against the bent edge forcing the pipe inwards against the copper gasket.
One thing that seems to happen to me is that in the process of wrestling the four pipes, eight clam shells, and 4 collars, a few times 1 or 2 of the collars will overlap each other on a pipe or two. Before I tighten anything at all, I always take the time to check that the clam shells are not overlapped. And are flat on the pipe. If they aren't flat it will never push against the lip of the header pipe.
A couple things that I have found that helps to hold the clam shells in place while doing this balancing act is silicne gasket sealer between the pipe and clam shell, or regular masking tape .
Silicone will not melt like grease or some other items, and if you make the masking tape about 1/4" or so, and keep it near the flat edge of the clam shells, it will eventually smolder away and can't be seen sticking out of the collars. Masking tape around the OUTSIDE of the clam shells, and the silcone between the header pipe and clam shell, just like you are glueing them to the pipe.
Now if I understood your question correctly I think you may have the answer....LOL
09 Jun 2009 19:18 #297843 by otakar
Yes, tape works fine. I also use a rubber band. They just burn off during the first start-up.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
09 Jun 2009 20:02 - 09 Jun 2009 20:03 #297870 by Patton
Replied by Patton on topic Need some help with exhaust
:woohoo: :laugh:
Smells like . . . VICTORY! :cheer:
Good Luck! :)
Last edit: 09 Jun 2009 20:03 by Patton.
10 Jun 2009 04:29 #297963 by N0NB
Replied by N0NB on topic Need some help with exhaust
I found that after installing a stock exhaust on the 650 that one wouldn't tighten up and made a little noise. I rode it about 20 miles and put it away. The next day I retorqued the exahust collars and that one drew right in. It has been quiet ever since.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
10 Jun 2009 18:47 #298168 by Hayden1977
Replied by Hayden1977 on topic Need some help with exhaust
Wanted to say thanks to you guys! I went with the rubber band suggestion and it worked like a charm. I even took another tip and installed the head pipes first and then added the collector/muffler. I paid the price for having the bike apart for a while and forgetting how everything came off.
10 Jun 2009 18:53 #298173 by timebomb33
Replied by timebomb33 on topic Need some help with exhaust
in order to use the v&h sidewinder you might have to rake the frame to prevent interfernce between the front wheel and the pipe under hard braking. especally the pro-pipe. it is alot bigger pipe physically.
I THINK MY POWERBAND BROKE
