Newbie with motor issue 80' 250 LTD
09 Jun 2009 18:36 #297819 by dearthchris
Newbie with motor issue 80' 250 LTD was created by dearthchris
So I am learning to ride on a 1980 KZ250 LTD. The bike has just over 7K on it and seems pretty solid. Bike starts good, idles good, and when it runs, well that is the problem. The bike hesitates, sputters, backfires, and feels underpowered when I am riding it out. The motor is getting mega hot. Smoke comes out of the cam where the points are. I put in a new spark plug and battery, and the new spark plug is white and not "tan" at all. It is clearly not running properly. The gaps on the plug and points is correct.
My neighbor seems to think that it is running "too lean". Please HELP!
Should I have the jet opened up? Should I also change the points and put in a new plug?
Thanks Guys!
  • Iron Duke
  • what are you rebelling against?
09 Jun 2009 21:08 #297912 by Iron Duke
Replied by Iron Duke on topic Newbie with motor issue 80' 250 LTD
whats the center electrode look like? possable causes preignition,overadvanced timing,incorrect advance,fuel octane rating not right,incorrect plug heat range that gives you a start, oh if I havent said it welcome to KZR,pics please
1982 KZ550 LTD C-3
1979 XS1100 F Yamaha
10 Jun 2009 10:26 #298018 by 650ed
Replied by 650ed on topic Newbie with motor issue 80' 250 LTD
Welcome aboard. Before "opening up" anything I would give it a thorough tune-up, make sure the timing advancer is lubed and moving freely, clean the carb, etc. Also, have you changed the oil/filter and made sure it isn't overfilled? Is the exhaust and airbox stock? Ed
  • Kawickrice
10 Jun 2009 10:32 #298019 by Kawickrice
Replied by Kawickrice on topic Newbie with motor issue 80' 250 LTD
Has the bike sat for an extended period of time? You say it idles fine but runs kinda sluggish. Maybe your carb needs a good cleaning.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
10 Jun 2009 12:15 #298035 by Tyler
Replied by Tyler on topic Newbie with motor issue 80' 250 LTD
Your 250 was set up from the factoery to run on the lean side, so if there is any build up in the jets engine will be very lean. I would clean and inspect the primary and secondary main jets and the pilot system (which may or may not have a rubber plug installed in it). I would also reccomend the factory manual becasue it has very detailed drawings of the carburator passages and a great section on "Theroy of Operation" that makes cleaning an inspection a breeze. I owned one of those bikes for over 10 years and the carb has to be kept very clean or they get temperemntal. I opened up the both the primary and secondary jets to get just a little more fuel and my bike ran much better, but its VERY touchy and easy to run super rich. Also verify the diaphram on top of the carburator is not torn, that will casue all sorts of problems. The rubber intake manafold and air box need to be in good condition as well because air leaks have a big effect on such a small displacement engine.
"74 Yamaha DT 400 Enduro
10 Jun 2009 14:20 #298065 by dearthchris
Replied by dearthchris on topic Newbie with motor issue 80' 250 LTD
Thanks, I'm going to get the carb ran through as soon as possible!
