Cylinder number 4 running cooler than the rest.
  • Koda1
  • Koda1's Avatar Topic Author
08 Jun 2009 13:23
#297343
Hello, I am a new member and had a question about a bike I recently purchased. It is an '82 KZ750 LTD with low miles. I had to clean the carbs because it would only run with the choke fully engaged.(the jets were all varnished, etc.)
I also needed to replace the wires and caps (they were leaking and gave a shock to the touch)
Everything else checks out fine, except now the #4 cylinder runs cooler, which may have to do with a rough idle. The bike runs great when riding. #4 spark plug was black and the others were a nice tan color.
Is the problem with the #4 carb or is it something else? Should I spend the money on a carb sync? Should I replace the idle jet?
PS The #4 cyl has good compression. No smoke billowing out of the exhaust. Can't see a thing!
Thanks!
'78 CB750K
'82 650 Nighthawk
'82 KZ750
"The problem with socialism is that you eventially run out of other peoples money"
M. Thatcher
  • donthekawguy
  • donthekawguy's Avatar
Re: Cylinder number 4 running cooler than the rest.
08 Jun 2009 16:36
#297380
Check the valve clearence and sync the carbs. Maybe run a bottle of sea foam through the tank-couldn't hurt.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • Locozuna
  • Locozuna's Avatar
08 Jun 2009 16:49
#297386
Since you just replaced the wires and caps get a good look at them at night in the dark and move them around to see if they are arcing to the engine. You say comp is good so I would think the valves are ok. Sometimes when the carbs get cleaned just a small piece of crap can do it. Did you put new lines and fuel filter in?
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • Koda1
08 Jun 2009 17:12
#297390
Thanks, I did install an in-line filter, but didn't replace the fuel line. I will look for arcing. I was hoping that I wouldn't have to tear down the carbs again, The rubber boots leading to the air box are a SOB to put on.
'78 CB750K
'82 650 Nighthawk
'82 KZ750
M. Thatcher
  • MFolks
  • MFolks's Avatar
08 Jun 2009 18:09
#297431
To soften the boots, use a hair dryer at medium setting.If replacing the boots with new ones, soak them in fairly hot water with a little fabric softener. It makes this chore easier.
  • JR
  • JR's Avatar
08 Jun 2009 18:28
#297446
Great looking bike you got there Koda1.
When I got my 750 a few years back I had carb problems and it took me 3 - 4 shots at cleaning them before I got it right. It was'nt enough to spray carb cleaner in all holes. It was only when I removed all jets. sparyed carb cleaner - wear safety glasses because that stuff will shoot back and get your eyes !!! - probe every hole I could find with a stiff bristle or gently with fine wire and made totally sure all passageways are clean. Only when I did all this did I get it right.
Are the carbs Keihins and did you remove the air mix screws at the top of the carbs towards the front or are they covered with a metal plug ?
I am a believer in using a synch tool on the carbs after I do anything to them. A good envestment in my humble opinion.
  • Koda1
08 Jun 2009 18:48
#297459
Thanks, I was afraid I might have to tear the carbs down again. I was thinking about a sync tool that sells out of England. I think it costs around $100.00. Do you have any suggestions?
'78 CB750K
'82 650 Nighthawk
'82 KZ750
M. Thatcher
  • Kawickrice
  • Kawickrice's Avatar
08 Jun 2009 19:02
#297466
If you think it might be a little trash in the carb, sometimes a good spirited ride will clear it up and sometimes not. I wouldn't recommend this if it may be a valve adjustment though. If it is in a certain rpm range I would run it in the range for a few times and see if it clears up. I do this before I tear them down for the upteenth time. Hitting reserve usually means a teardown for me no matter how clean my tank is. I figure if I pull the petcock every so often I will get most of the trash before it gets me.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
08 Jun 2009 19:50
#297491
Click here > Just Do It!
Good Luck! :)
  • 88alltrac
  • 88alltrac's Avatar
08 Jun 2009 21:07 - 08 Jun 2009 21:08
#297549
this problem sounds all too familiar, ay patton
81 KZ1000 K1
Lincoln NE
Last edit: 08 Jun 2009 21:08 by 88alltrac.
09 Jun 2009 02:54
#297629
Koda1 wrote:
...#4 cylinder runs cooler....
Would install brand new spark plug in #4 and test for combustion by allowing engine to run a few moments, then water spraying exhaust headers. Water should sizzle and instantly vanish.
If #4 is combusting, would take a test ride to determine whether the new #4 plug soots and fails.
As known, even perfect carbs can't compensate for defects in compression or ignition or fuel supply.
Good Luck! :)
  • JR
  • JR's Avatar
09 Jun 2009 06:36
#297656
Koda1 wrote:
................. I was thinking about a sync tool that sells out of England. I think it costs around $100.00. Do you have any suggestions?
Sounds like the Carbtune from Belfast. I have one and love it.
