How Do you Tighten the Chain on a 78 650 B
  • KOOL RYDER
  • Topic Author
  • KZ 650B2 / KZ 1000E
08 Jun 2009 09:21 #297291 by KOOL RYDER
How Do you Tighten the Chain on a 78 650 B was created by KOOL RYDER
My drive chain is loose and i would like to tighten it.
Anyone have any tips before I get into this.
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
08 Jun 2009 14:09 - 08 Jun 2009 14:09 #297350 by bountyhunter
Replied by bountyhunter on topic How Do you Tighten the Chain on a 78 650 B
Put it on the center stand. Loosen the rear axle nut and brake caliper and use the adjuster nuts to move the wheel to the rear. The chain should have about 1 - 1.5" vertical play in the center.
Last edit: 08 Jun 2009 14:09 by bountyhunter.
08 Jun 2009 16:48 #297385 by RacerZ
Replied by RacerZ on topic How Do you Tighten the Chain on a 78 650 B
On the center stand after loosening those items up, find the tightest spot in the chain and you should adjust the "Play" to be 1 to 1-1/4 from the tightest spot on the chain. Also this play is measured from the "Bottom Middle" of the chain travel. The Alignment marks on the swing arm chain are for reference, and aren't exactly perfect, so this is a good time to measure the distance from a stationary point, Center of the "Swing arm Pivot Bolt" to the Center of the "Rear Axle Bolt". Measure both sides and adjust to the same measurement value on each side and keeping 1 to 1-1/4 inch "Slack" in the "Bottom Middle" tightest point of the Chain, as this will give you better accuracy, as opposed to the "Alignment Marks" on the Swing arm. So Measure it left side and right side, Find the tightest spot in the Chain Travel as you spin it around by hand checking it from the Bottom Center of the Chain travel. When you find the tightest point, adjust from there.
