cam gasket
07 Jun 2009 07:19 #296948 by dustin
cam gasket was created by dustin
just got my cam gasket and little rubber half moon pieces but now i can't find my haynes manual. i was wondering if the top portion of the engine comes completely off when i go to replace that gasket or if i will have to remove a larger section of the engine to get at it.
07 Jun 2009 08:53 #296986 by Buda
Replied by Buda on topic cam gasket
I think you mean the cam cover gasket if so than yes just the cam cover has to come off.
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
07 Jun 2009 11:56 #297028 by dustin
Replied by dustin on topic cam gasket
thank you
07 Jun 2009 12:52 #297035 by MFolks
Replied by MFolks on topic cam gasket
An old racer's trick is to install them inside out(put the larger flange or lip on the inside of the engine) this reduces the chance of oil leaks more.
Make sure all cam plug areas are clean of oil.
07 Jun 2009 13:11 #297045 by donthekawguy
Replied by donthekawguy on topic cam gasket
What bike are you working on? On the 1000's the cam cover is sometimes a pain to get off. You will have to work it around the cam chain tower but it will come off through the right side.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
