clutch questions
- Davestradamus
01 Jun 2009 20:19 #295648
by Davestradamus
clutch questions was created by Davestradamus
i have just put the first 100 miles on my 1977 kz650b after a long time off the road. after letting the motor cool, when starting with the clutch lever squeezed the bike moved forward. i released the clutch lever and squeezed it again. i put the bike in neutral and started it. i drove home with little problem (aside from a small intermittent miss that concerns me a bit). The same problem returned when i arrived home.
possible problems:
clutch cable too loose/tight?
warn clutch plate?
need oil change?
gas in crank case?
any help would be great!
thanks!
david
possible problems:
warn clutch plate?
need oil change?
gas in crank case?
thanks!
david
- Thank you received: 2829
01 Jun 2009 20:31 - 01 Jun 2009 20:32 #295654
by 650ed
Replied by 650ed on topic clutch questions
If you haven't done so over the past year, I would definitely change the oil & filter and lube & adjust the clutch cable. Ed
Last edit: 01 Jun 2009 20:32 by 650ed.
- bountyhunter
- Thank you received: 337
01 Jun 2009 20:48 #295658
by bountyhunter
Replied by bountyhunter on topic clutch questions
Davestradamus wrote:
I think most bikes with a wet clutch do this to some degree. Put it in neutral before you start it, don't leave it in gear and pull in the clutch.i have just put the first 100 miles on my 1977 kz650b after a long time off the road. after letting the motor cool, when starting with the clutch lever squeezed the bike moved forward.
- trianglelaguna
- Thank you received: 235
01 Jun 2009 20:58 #295660
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic clutch questions
ditto....would not hurt to follow the manual and start at the motors clutch adjuster then cable then bar nut.....but nuetral is the way to go....good luck...oil changes are cool anyway...bountyhunter wrote:
1976 KZ900
2003 ZX12R
2007 FZ1000
