- Thank you received: 20
lobe centers 1015cc
- nads.com
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
Thought I had norris .407 cams @.020 and 280deg. They have kh259 on them. I don't know if kenny Harmon made .407's. But the degree wheel seems to be telling me they would be the former if set up at 108deg centers. Meaning the op. and cl. numbers 20 and 80 would would be just that. Anyway, i guessed on max lift point back then and tightened up the bolts. Now I checked after 3years of good power up top and able to beat 600cc bikes. And LO! 115 actual center on the the intake. I don't know if I want to change it. Common sense tells me maybe pull it down and have more power up to the top and keep the top end as well. Maybe they beat me from the start because the torque is lacking. I havnt ridden for 2years. No license till april so I won't know till then. But gut feeling tells me I could loosen the bolts, advance the cam slightly and though the number will barely change the power band will change. I don't want it down. I need the high rpm pull. How much I'm missing I'll find out later. Even at 155psi I can't have the timing set anywhere near the fire mark. If I do it pulls like a truck and the front wheel lifts at 10mph and it hits the wall early with vibration and such. 80mph in fifth and it vibes pretty good. The way it's set up at ll5center and the timing backed way off from the mark, it's smooth in third gear at 90mph. It actually comes on at 85 or so in that gear. I gave them a bump and it seems it has more compression but it could be the oil I put in the cylilnders is sealing the rings good right now. I remember stock the bike had torque and a broad range of it at that but it's nothing like it is now. Used to pull the best at 55 in third. Yucky though compared to what i got going on now. There is a guy on this site that stated he had his intake at 112. I think I know why. Either he and I are idiots, have a diff. riding style or the the way we are set up is just plain better. All I know is when I get to drive again I'm setting up the deg. wheel on the rotor side with the numbers facing toward the motor so it's quick set up. And folks, the degreeing is ON! And I don't think you can ever get a dial and base set up rock solid. I've learned enough to know that all the equipement lies. It's more like give the cam a bump, take down the new numbers and go. The numbers don't mean anything they are merely for reference only. Dirty white lies. Lies I say! Everything lies. But smoking a rocket is not a lie. Guess I'll have to check the exhaust to see what kind of voo doo I did there. Clearances were right on ranging from .006 to .014 lol. HOLY shnikey! What was I thinkin? I ported the crap out the head, probly all the power too, and I never even went with three angles or bowl blending or nuttin. But least I don't have skinny azz lil valve seat that crush in at too grand run the vavles hot as molten lava. Did you guys know that at 115lc u have over .100 piston to valve clearance and cannot bend a valve no matter what you do? I miss bending valves. It's like showing a battle scar. And just to make you all squirm I used miss matched cam caps on purpose. But it didn't work. It didn't blow up. The bright side is finally gota dyna. I drink gallons of water after drinking all weekend and smoking everyone on the pool table. It doesn't effect the way the bike runs either. Just whether or not it will start. Think so far i've drank countless ignitions, speedos, seats, regulators, side covers etc. Gets expensive when let things go too long. So my advice is just don't buy anything.
What is the elevation where you live? What size carbs do you use?
- modprod
I've said this several times before on here but again, just read the #s and do the calcs. Not rocket science just beginning dial indicator setup and usage. If your not getting repeatable numbers within 1/2 degree your doing something wrong! I remember some guy on here talking about trying to calc the valve clearences into the calulations. Big mistake! Why bother? Sure way to make a blunder! Just setup and read the numbers.
- nads.com
- nads.com
