removing aluminum covers from engine for polishing
- Z1Rider
31 May 2009 15:31 #295336
by Z1Rider
removing aluminum covers from engine for polishing was created by Z1Rider
I'm taking off the aluminum engine covers to polish. The cover behind the shifter with the tear drop access cover is obviously part of the clutch adjuster. The 12mm nut with the snap ring behind it doesen't spin easily and I feel like if I force it I will break something. What is the process for removing this part with out damaging it???? I know I need to buy a Clymer manual....but I'm trying to get this thing off tonight before I have to go back to work. :S
- roy-b-boy-b
- Thank you received: 103
31 May 2009 17:30 #295368
by roy-b-boy-b
Replied by roy-b-boy-b on topic removing aluminum covers from engine for polishing
You don't have to remove it. Just remove the shifter the four bolts and the clutch cable. Roy
- Z1Rider
01 Jun 2009 05:26 #295446
by Z1Rider
Replied by Z1Rider on topic removing aluminum covers from engine for polishing
Thanks Roy, got it.
