How long should a clutch cable last
- Buda
31 May 2009 06:47 #295251
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
How long should a clutch cable last was created by Buda
I bought my bike last summer from a friend at about this time of year. The clutch cable was new then. It broke yesterday. Are the motion pro cables any good?
Thanks
Tom
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- Old Man Rock
- Thank you received: 225
31 May 2009 06:52 #295253
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic How long should a clutch cable last
Unknown what you had in it to start with but with proper tension adjustments, cable lubrication, clutch operations a cable should last a good couple of years plus.
Jeff @ Z1 has them for ~ $10-15 pending models...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Buda
31 May 2009 06:57 #295256
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Replied by Buda on topic How long should a clutch cable last
I looked on Z1 last night and its $15 cheap. The last one only lasted one season of riding.
Tom
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- Old Man Rock
31 May 2009 07:08 #295260
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
All I can inform you is I obtained my clutch cable from Z1 and I was sent a Motion pro cable and have had no problems...
Kawasaki OEM cables ~ $35 plus tax... Maybe you need to go this route...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- otakar
31 May 2009 07:09 #295261
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic How long should a clutch cable last
I had the same problem on my 76 KZ900, where they would snap once a year. Until I called Motion Pro, and found out that I was installing them wrong. Now I am getting over three years and going.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Buda
31 May 2009 07:16 #295267
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Mabey I wasnt clear. I ment the the price was cheap not the cable. I order just about all the parts I buy from Z1 just to help keep them around. I'll buy 2 from Z1 for the price of 1 oem cable.
Thanks
Tom
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- Old Man Rock
31 May 2009 07:24 - 31 May 2009 07:25 #295270
by Old Man Rock
otakar .....Well don't keep us in suspense, do share what they informed you of....
Hell, hard to believe there a wrong/right way to do this on a clutch cable but I'm game for learning no doubt....
Seriously speaking! I'd like to know if I have a possible FUBAB coming if installed incorrectly....
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
...Until I called Motion Pro, and found out that I was installing them wrong.
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 31 May 2009 07:25 by Old Man Rock.
- otakar
31 May 2009 08:17 #295279
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Because as most of us know, that the cable almost always breaks at the top swedge, the trick is, how the upper adjusters are positioned. They should always be turned so that the cable pulls straight against the swdge, and is not rubbing against eny of the edges which make up the slot in the adjuster. Also the cable must be the right length. Most cables today are made as universal cables and are made purposely too long to fit more bikes. If you have a cable that is too long it will wind up making undesirable "S" turns and put undue stress against the swedge. Third thing is proper lubrication. I just went to "Motion Pro" and had them make me cables that are the exact length I needed. Most of us change handle bars and this actually causes problems with pull cables. A custom cable from Motion Pro cost me only about $30. but I hav not had to replace one since I installed it. This also saves time and a mess, as we all know it is to remove the countershaft sprocket cover and deal with the lower part of the cable on a KX1000 or 900.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Buda
31 May 2009 08:57 #295282
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Mine broke under the sprocket cover where it hooks to the clutch release. There is a spring missing that goes over the cable under the cover, could that cause my problem?
Thanks
Tom
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- otakar
31 May 2009 09:10 #295283
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
That will definitely cause a problem. Because the bracket that the swedge rests in will flop around and the cable is free to bend while not under tension. Any light spring will do in its place that will hold constant pressure on the cable
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- MDawnz1
- Thank you received: 27
31 May 2009 21:48 #295425
by MDawnz1
1974 Z1a, still 903
Replied by MDawnz1 on topic How long should a clutch cable last
The question is "How long should a clutch cable last "
Answer ....1 Year ....
Buy your bike NEW cables every year for Christmas.
Cheap to keep it happy, you end up with good spares and NEVER get stuck on the road with a busted cable.
1974 Z1a, still 903
