750 twin engine not starting
31 May 2009 05:15 #295245 by 82_twin_KZ
750 twin engine not starting was created by 82_twin_KZ
I have an 82 kz750csr twin that will not start. I thought the ignition was bad so i converted back to the old point and condenser style ignition. i followed the service manual on how to set it up. i am pretty sure that i got it dead on. It will back fire but that is it. Could the cam timing be off? If anyone knows a lot about these twins please help me out.
thanks,
Paul
31 May 2009 06:54 #295254 by flht1997
Replied by flht1997 on topic 750 twin engine not starting
Rotate the ignition advance 180 degrees and try it
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
01 Jun 2009 12:06 #295497 by bountyhunter
Replied by bountyhunter on topic 750 twin engine not starting
Check to see the points are opening at a crankshaft rotation point near the "T" mark. You can see it under the points cover. As stated above, it is possible to get the advancer assembly on 180 out.
02 Jun 2009 06:58 #295715 by 82_twin_KZ
Replied by 82_twin_KZ on topic 750 twin engine not starting
i have done this already. it still has not helped. any other ideas?
02 Jun 2009 13:48 #295809 by bountyhunter
Check for hot spark.
Check spark plugs to see if they have fuel on them.
Check compression.
