APE K410 Cams, the right choice for me????
- chiefgto
- War was just a game we played when we were kids.
MTC 1075 10.5-1 pistons.
3 angle valve job with Stage 1 port and polish, APE springs and guides.(15-20% advertised flow increases)
WiredGeorge Mikuni BS34 carbs.
Dyna 2000 ignition.
Vance and Hines 4 into 1 exhaust.
Ape slotted 32 tooth cam sprockets.
This bike will be a 99% daily rider with a 1% probability of dropping a tooth on the front sprocket and taking it to the local drag strip on "open" nights.
Any suggestions on cam timing would be greatly appreciated as well. Thank you for your help gentlemen.
1979 LTD1000 B3 Chassis.
1980 LTD1000 Engine.
MTC 1075 10.5-1 pistons, 3 angle valve job with mild port and polish. V&H 4 into 1 pipe. Mikuni BS34 Carbs. Dyna 2000 ignition.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- APE Jay
- Banned
- Thank you received: 58
Jay
- nads.com
- Thank you received: 20
Yours is exactly the combo those cams are designed for. We sell 1075 "street Racer" engine kits that come with those cams. It is one of the most popular engine kits ever sold for the KZ. You tellem Jay!
Jay
- Z1000Lover
- Sandy
- Fly High,Tony
- Thank you received: 13
Jay
That's what I thought too.:huh:
I'm using them on my 1105 engine,and I love them!
1977 KZ1000 A-1
- joehooper
If you had Wiseco 72mm pistons rated at 10.25:1 compression then I would agree with everyone else that it is the best camshaft for your setup.
However, you have MTC pistons rated at 10.5:1 compression.
Compression ratios can be very confusing since every piston manufacturer has their own way of calculating them.
I have attached a picture of a 72mm MTC piston and a Wiseco piston side by side the MTC piston is on the left.
As is clearly visible, the MTC piston is going to have a far higher compression ratio regardless of who calculates it than the Wiseco.
Check your cranking compression using a standard compression gauge and the starter motor.
My guess is that your motor will be over 200 psi.
That is way more than 10.5:1.
If you were to install the PSP-3X camshaft which has very long duration (282 degrees at .030" lift, along with .418" total lift) it would not only drop your cranking compression in the neighborhood of 165 psi but it would give you phenominal performance throughout the RPM range.
Pit Stop Joe
By the way, it sounds like I did your head and cylinder.
- DoubleDub
- Visitor
- les holt
- Thank you received: 288
Les
