- Thank you received: 2
flywheel puller
- pburnhamb
29 May 2009 17:40 #294904
by pburnhamb
1978 kz650b (810, 750 head)
1976 kz900
1977 xs650
flywheel puller was created by pburnhamb
I borrowed a flywheel puller from the motorcycle shop down the road. I threaded it on and used excessive force but still stuck on the crankshaft. I dont have an impact wrench and the crankshaft is "out of the engine" (top case half is off). i read in an earlier post about a ballbearing between the crankshaft and the puller.....is that the key?? a ton of friction right now with flat end of puller against flat end of crankshaft.. do i NEED a ball bearing....???? the store is closed for the night.
1976 kz900
1977 xs650
- keith1
29 May 2009 18:59 #294918
by keith1
Replied by keith1 on topic flywheel puller
on the 1000, the book says to put a ball bearing in, then thread in the steering stem bolt....i dont know if the smaller bikes are the same.....good luck...keith
- MDawnz1
- Thank you received: 27
29 May 2009 19:31 #294926
by MDawnz1
1974 Z1a, still 903
Replied by MDawnz1 on topic flywheel puller
Once you get the puller tight ,hit the bolt head flush with a hammer. Be ready to catch it , it will JUMP right off.
1974 Z1a, still 903
- pburnhamb
29 May 2009 19:46 #294932
by pburnhamb
1976 kz900
1977 xs650
Replied by pburnhamb on topic flywheel puller
The puller that I have looks just like a bolt, I don't see how hitting it with a hammer is going to push the flywheel off the crankshaft because it's threaded to the flywheel but I'll try. Thanks.
1976 kz900
1977 xs650
- bountyhunter
- Thank you received: 337
29 May 2009 20:58 #294937
by bountyhunter
Replied by bountyhunter on topic flywheel puller
The puller "bolt" threads into the flywheel and pushes on the crankshaft. I believe he means when it lets loose the flywheel with threaded bolt will pop off and try to hit the floor if not restrained.
