Pitstop Performance Orlando FL?????
  • chiefgto
  • chiefgto's Avatar Topic Author
  • War was just a game we played when we were kids.
28 May 2009 12:57
#294660
What's the word on this place? Anybody ever use him or know anything about him? He has a 100% feedback rating on Ebay. I would appreciate any help. Thanks.
1979 LTD1000 B3 Chassis.
1980 LTD1000 Engine.
MTC 1075 10.5-1 pistons, 3 angle valve job with mild port and polish. V&H 4 into 1 pipe. Mikuni BS34 Carbs. Dyna 2000 ignition.
  • keith1
  • keith1's Avatar
Re: Pitstop Performance Orlando FL?????
28 May 2009 16:40
#294695
top notch guy in my book....i bought mtc pistons and bored out jugs from him on ebay....he end gapped rings and etched cylinder number under piston skirts...all i had to do was put it together...i also sent my head to him and had him do the service he has listed....new guides, seals, everything cleaned up, stems done as needed, shimmed up with the cams i sent him....had him do the surface finish he bakes on to match the jugs....looks great..see avatar......great communication also...i would definitely use him again......keith....
  • otakar
  • otakar's Avatar
28 May 2009 16:58
#294701
In my book he's the best. I used him once and he had me hooked. Now I have used his services four times in the last 2.5 years and plan on going to him more. The best prices you will ever find and the service is top notch. His name is Joe Hooper and I give him an AAAA++++ He will bend over backwards for you.
Otto Kudrna GySgt USMC
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • Old Man Rock
  • Old Man Rock's Avatar
28 May 2009 19:40
#294751
Purchased my CAM Degreeing kit from them, no problems what so ever...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • chiefgto
29 May 2009 13:54
#294853
Whew! That's a relief! I asked this question AFTER I mailed him my cylinder block and head. I went with the Ebay feedback rating and sent them out, THEN I realized I could bounce it off you guys in here too. My excitement got the best of me I suppose. It looks like I'm going with just about the EXACT SAME set-up as you Keith, right down to a set of WiredGeorge BS34 Mikuni carbs. I'm going to break the motor in with the stock cams, then I might drop in an APE K-410 cam afterwords. MR. Hooper said it was the way to go for a street bike. I can't wait!
  • otakar
  • otakar's Avatar
29 May 2009 17:17 - 29 May 2009 17:18
#294893
On the last project he did for me only a couple of weeks ago, I had hip punch my J motor to 1140 and he had a set of custom pistons made for me by MTC to match my 84 GPz head. I bought a set of K410 cams from him out of which I will use one for the exhaust. I will use a Vance & Hines .417 for the intake with 39mm intake valves. The head is my work and the Mikuni BS34s are also my work, although I will convert the bike to fuel injection. you can see the entire project here. kzrider.com/index.php?option=com_kunena&...w&catid=11&id=169462
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 29 May 2009 17:18 by otakar.
  • chiefgto
30 May 2009 08:35
#295021
Damn! That bike is very nice Gunny! Your paint work is top notch. I took auto body at my high school and I am ate up with a spray gun in my hands, I'm talking a serious disaster! Would you gunkote your engine cases? What about heat dissipation?
  • otakar
  • otakar's Avatar
30 May 2009 09:02 - 30 May 2009 09:04
#295028
I would not "Gun-Kote" engine cases or the cylinder block. I would use "Polane" Knowing what I know now, I would use Gun-Kote only on smaller parts. Gun-Kote works very well on small steel parts. Because Aluminum is soft, Gun-Kote has a habit of chipping off. I think that "Polane" is the best for Aluminum There is not much problem with Heat unless you really cake it on. Polishing an engine is actually sometimes worse, and Chroming engine parts is by far the worst.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 30 May 2009 09:04 by otakar.
