- Thank you received: 4
Compression Check Cold
- KawiConvert
27 May 2009 22:01 #294548
by KawiConvert
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
Compression Check Cold was created by KawiConvert
Performed a compression check on a room temperature (105 F) kz750 and wanted to know what kind of figures I should be expecting. I know it says to warm the engine up first, but as this one is out of the bike I don't have much of a choice.
Thanks,
KC
Thanks,
KC
- Thank you received: 797
28 May 2009 06:54 #294596
by 531blackbanshee
Replied by 531blackbanshee on topic Compression Check Cold
takes at least 65lbs.of compression to create combustion.i have seen em run with less but not good and not for long.
a good runner should have at least 100lbs and a stout engine should be around 130-140.
hth
leon holmes
hth
leon holmes
- KawiConvert
28 May 2009 09:22 #294628
by KawiConvert
Replied by KawiConvert on topic Compression Check Cold
Ok, in the coditions above I check and found one cylinder was around 15psi, the others were 50-70. Added oil to the low one and got it to about 120psi. Figure rings and seals if I go this route then. I just wanted to see what range to expect with a cold compression test.
- JR
- Thank you received: 448
28 May 2009 17:19 #294709
by JR
Replied by JR on topic Compression Check Cold
I see 145psi on all four cylinders on a cold engine with WOT
- bountyhunter
- Thank you received: 337
28 May 2009 17:23 - 28 May 2009 17:25 #294711
by bountyhunter
Replied by bountyhunter on topic Compression Check Cold
KawiConvert wrote:
I think the cold reading should be not more than maybe 30 psi lower than nominal (hot) reading.Performed a compression check on a room temperature (105 F) kz750 and wanted to know what kind of figures I should be expecting. I know it says to warm the engine up first, but as this one is out of the bike I don't have much of a choice.
Thanks,
KC
Last edit: 28 May 2009 17:25 by bountyhunter.
- KawiConvert
28 May 2009 17:53 #294716
by KawiConvert
Thats what I was afraid of. Time to keep looking or invest some money in a possibly shot engine.
