- Thank you received: 337
Zinc (ZDDP) For Your Oil: EBAY #170322181084
- bountyhunter
27 May 2009 21:30 - 29 May 2009 22:01 #294540
by bountyhunter
Zinc (ZDDP) For Your Oil: EBAY #170322181084 was created by bountyhunter
You can buy it in a bottle and add it to the oil if your oil doesn't have enough.
www.zddplus.com/
I wish I had a reference that told how much ZDDP was currently in the various name brand oils.
ADDED 5/29: The price on ZDDP Plus is $10/bottle + shipping. I found an ebay item #170322181084 where you can get six bottles for $49 with free shipping in case anybody else wants some.
I tried to post this info in a separate new thread but the server here crashed for the tenth time tonight.
www.zddplus.com/
Last edit: 29 May 2009 22:01 by bountyhunter.
- otakar
28 May 2009 05:44 #294586
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Speaking of Zinc (ZDDP) For Your Oil
Thanks for the link. Since I like to run synthetic oils which have no ZDDP in them I plan on buying a bunch. Since having more than required will not hurt the engine and too little is better than none, I plan on using 1/2 bottle for every 4 quarts. After all it is $10 a bottle plus shipping.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- austin3119
- Thank you received: 7
28 May 2009 11:11 #294646
by austin3119
Replied by austin3119 on topic Speaking of Zinc (ZDDP) For Your Oil
The holy grail of oil discussions. Have fun, you can check the UOA's for current amounts of zddp in the various oils.
www.bobistheoilguy.com/forums/ubbthreads.php
- Mcdroid
- Gone Kwackers
- Thank you received: 317
28 May 2009 11:54 #294649
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic Speaking of Zinc (ZDDP) For Your Oil
austin3119 wrote:
That is a great site...nice link. And I thought we were geeks...just read the comments on the oil blog :laugh: :laugh: :laugh:
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- bountyhunter
28 May 2009 17:18 #294708
by bountyhunter
Replied by bountyhunter on topic Speaking of Zinc (ZDDP) For Your Oil
otakar wrote:
I am not 100% certain that is correct. I recall researching it and I vaguely remember that if the concentration gets too high it forms deposits in the combustion chamber? maybe somebody else knows about that, I just recall that about 2000 ppm was the sweet spot and going significantly higher had some possible negative aspect. But, with the old engines with camshafts like the KZ's, having no zinc will wear them out very quickly. So, too little is way worse than too much.Thanks for the link. Since I like to run synthetic oils which have no ZDDP in them I plan on buying a bunch. Since having more than required will not hurt the engine
- Thank you received: 2829
28 May 2009 18:33 - 28 May 2009 18:33 #294726
by 650ed
Replied by 650ed on topic Speaking of Zinc (ZDDP) For Your Oil
Bountyhunter wrote: "I wish I had a reference that told how much ZDDP was currently in the various name brand oils"
There are references on the internet that show this, but BEWARE - all the tables I found that show a comparison between the various brands are old, They do not show the current ZDDP levels after the poil comapnies changed their formulas. The good news is, if you go to the web site of the oil companies and search a bit you can usually find the levels. For example, Castrol GTX removed all ZDDP (see Castrol answer to question2). Mobil-1 Racing 4T 10W40 oil has 1600 PPM (parts per million) which is the highest I've found.
see Mobil .
Other companies generally have the current info, but it may be a little hard to fin.
see Mobil .
Last edit: 28 May 2009 18:33 by 650ed.
