- Thank you received: 2098
How to measure displacement?
But am uncertain with regard to most commonly accepted method of measuring displacement.
Is displacement measured as the difference between combustion chamber volume at bottom dead center and at top dead center?
Or measured as the cylindrical volume from top of the piston at bottom dead center to top of piston at top dead center (or top of cylinder where domed piston protrudes above cylinder)? And ignoring volume of concave area in head around the valves?
Or some other means, such as volume of air intake during the intake stroke from tdc to bottom dead center?
Regardless of measurement method, it seems with all else equal that changing to a higher compression piston would decrease the measured displacement because the higher piston dome now occupies some of the displacement volume.
Thanks for some insight on this.
Good Luck!
- Sandy
- Fly High,Tony
- Thank you received: 13
1977 KZ1000 A-1
- loudhvx
- Thank you received: 1616
cylinder area x stroke. (by cylinder area, I mean cross sectional area)
This is because it's the volume of flow the cylinder will produce that's being measured. Therefore, the volume of the combustion chamber at TDC is not included. That same volume is also not included at BDC.
If the piston were to move very slowly, and the valves open and close fully at TDC and BDC, the volume of air the cylinder will draw until BDC, and therefore displace as it moves up to TDC, will be
CylinderArea x Stroke, regardless of chamber shape or piston shape.
Therefore, combustion chamber changes do not alter displacement. As long as bore and stroke stay the same, displacement stays the same.
EDIT: to confirm this with Sandy's link...
cylinder area =
= pi x (CylinderRadius squared)
= pi x (CylinderDiameter squared) / 4
= pi / 4 (CylinderDiameter squared)
this is approximately
= .7854 x (CylinderDiameter squared)
Bore is Cylinder Diameter so
= .7854 x bore x bore
so approximate displacement
= .7854 x bore x bore x stroke
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- loudhvx
without looking it up memory tells me its bore x bore x stroke x pie x number of cyls
have to divide that pie by 4 in order for the bore area to be correct.
mmmmmmmm, pie
1981 KZ550 D1 gpz.
Other links.
- N0NB
- Blue handles better
Engine displacement is the volume swept by all the pistons of an engine in a single movement from top dead center to bottom dead center.
Wikipedia has plenty of information on Engine Displacement .
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel )
...volume of the combustion chamber at TDC is not included. That same volume is also not included at BDC.
If the piston were to move very slowly, and the valves open and close fully at TDC and BDC, the volume of air the cylinder will draw until BDC, and therefore displace as it moves up to TDC, will be Cylinder Area x Stroke, regardless of chamber shape or piston shape.
Therefore, combustion chamber changes do not alter displacement. As long as bore and stroke stay the same, displacement stays the same....
Thanks!
- Nebr_Rex
- Thank you received: 300
try radius X radius X pie X stroke
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- bountyhunter
- Thank you received: 337
I believe it is piston top area times stroke. Take 1/2 piston diameter X 1/2 piston diameter X 3.1416 X stroke to get displacement of single cylinder. To get total displacement, multiply times number of cylinders.without looking it up memory tells me its bore x bore x stroke x pie x number of cyls
- PLUMMEN
- Thank you received: 104
