Is it true?
- kzmarvo
25 May 2009 20:26 #294046
by kzmarvo
Watch it folks,i have sticky fingers when it comes to a nice looking set of handle bars:)
Is it true? was created by kzmarvo
I was told that running my pipe cut way short and open will burn the valves around 4000 miles or so,is this true?
- PLUMMEN
- Thank you received: 104
25 May 2009 21:01 #294065
by PLUMMEN
Replied by PLUMMEN on topic Is it true?
theres a reason why we used to shove a towel in the end of an open header after racing,ive since learned to run atleast an endcap
- Bluemeanie
- Thank you received: 14
26 May 2009 06:40 #294126
by Bluemeanie
Replied by Bluemeanie on topic Is it true?
Having an exhaust like that allows cool air to go up to the hot valves and possibly warp them.
- bountyhunter
- Thank you received: 337
26 May 2009 15:40 #294182
by bountyhunter
Replied by bountyhunter on topic Is it true?
Bluemeanie wrote:
Yep, that's what I was taught as well.Having an exhaust like that allows cool air to go up to the hot valves and possibly warp them.
- kzmarvo
26 May 2009 15:58 #294187
by kzmarvo
Replied by kzmarvo on topic Is it true?
When the bike is off is that what you mean?
- Thank you received: 2098
26 May 2009 16:45 - 26 May 2009 16:45 #294203
by Patton
Replied by Patton on topic Is it true?
kzmarvo wrote:
When a hot motor is first shut off, am guessing the towel stuffed into exhaust is to help keep the hot air inside the pipe and prevent cooler outside air from entering the pipe and traveling up to the hot exhaust valves and cooling them too quickly.
Was taught not to run the engine without headers attached (exhausting from head ports directly into open air), as that exposes hot exhaust valves to open air whereby the valves may be warped.
Am thinking that running headers alone isn't so risky as running without headers. But don't know how short the headers could be without genuine risk.
Am thinking that running just headers likely results in poorer overall performance, even if it doesn't risk exhaust valve damage.
And that racing performance will be better with a good 4>1 exhaust system, and poorer if just running open headers.
Good Luck!
Good Luck!
Last edit: 26 May 2009 16:45 by Patton.
- kzmarvo
26 May 2009 17:04 #294207
by kzmarvo
lemmee get a pic on here...1 sec
- kzmarvo
26 May 2009 17:10 - 26 May 2009 17:11 #294208
by kzmarvo
Last edit: 26 May 2009 17:11 by kzmarvo.
- Bluemeanie
27 May 2009 06:14 #294329
by Bluemeanie
Very nice looking, what kinda swing arm ya got back there? Would highly recommened running some kind of muffler as the PoPo wouldn't like you!
- timebomb33
27 May 2009 06:24 - 27 May 2009 06:27 #294332
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Is it true?
the only guy's that you will ever see running open shorty pipes like that are guys that are running injected nitro in there big inch drag motors and hillclimbers that are running huge amounts of alcohol through their 1400cc+motors and the do it mostly because of ease of maintenence easier to remove and replace one pipe than 4 after it has been crushed it isn't for a performance advantage that's for sure. i can tell you from personal experiance after running straight wide open pipes for awhile on ridgid framed xs650 they are a total nightmare when it comes to the gestapo you might as well put a sign around your neck saying kick-me. the cops were on me all the time until i put mufflers on it. and lo and behold the bike ran better as well. so two benifits came out and slapped my hard core biker ass the bike ran better and the coppers were gone so good news on both fronts. and what the hell is that sign over your door way it had better be leading to the bathroom!!!!!!!!!!
Last edit: 27 May 2009 06:27 by timebomb33.
