ID this cam and head pls.
- Yojymbo!
25 May 2009 13:44 #293908
by Yojymbo!
ID this cam and head pls. was created by Yojymbo!
This is supposedly from an 83 GPZ, I was considering buying for the cams. I was looking at the picture and noticed it has what appears to be a tachometer gear and outlet, which was not on GPZs.
kzrider.com/index.php?option=com_marketp...&adid=3154&Itemid=46
- timebomb33
- Thank you received: 10
25 May 2009 13:50 #293911
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic ID this cam and head pls.
it looks like he might have the wrong picture up it looks to me like a 1000 head it has the top idler and peanut link cam sprockets also has slide type carb boots with vacuam ports not set up for cv carbs at all and a tach drive as well but you already saw that
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
25 May 2009 14:53 #293931
by The Gringo
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Replied by The Gringo on topic ID this cam and head pls.
I have to agree with TB that looks to be a head from a 900 or 1000. It is for sure not from a GPZ750 if it were it would use a hyvo type cam chain and not the roller setup you see. Also would not have a tach drive and the 750's don't use that type of cam hold down cap.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- APE Jay
- Banned
- Thank you received: 58
25 May 2009 14:56 #293932
by APE Jay
Replied by APE Jay on topic ID this cam and head pls.
Can't see the link, but there were no aftermarket billets made for the GPZ J motors. We make an adapter sprocket that allows you to run earlier KZ cams in the GPZ. Those cams have a tach gear .
Jay
Jay
- RacerZ
25 May 2009 15:25 #293936
by RacerZ
Replied by RacerZ on topic ID this cam and head pls.
- RacerZ
25 May 2009 15:26 #293937
by RacerZ
- JR
- Thank you received: 448
25 May 2009 17:38 #293969
by JR
Replied by JR on topic ID this cam and head pls.
Does'nt look like anything under my valve cover so not a regular 750/4 head either
- timebomb33
25 May 2009 18:18 #293987
by timebomb33
the thing that makes it look like a 1000 head is the 8mm exhaust studs unless they have been changed it does look like a nice clean useable head for a guy like me though.
