- Thank you received: 1
WANTED: '80 KZ750E cam chain tensioner
- Carr_113
25 May 2009 10:13 #293867
by Carr_113
'74 Z1-A
'80 KZ750E
'80 GS750E
'81 KZ440
'79 XS650 (needs love)
'72-'73 CB350 (3 or 4, in pieces)
WANTED: '80 KZ750E cam chain tensioner was created by Carr_113
I'm looking for a complete good/excellent condition cam chain tensioner of "split-wedge" type to replace the crappy OEM one on my KZ750. If anyone has one of these available, reply or PM me with asking price and pics if possible. Thanks!
'74 Z1-A
'80 KZ750E
'80 GS750E
'81 KZ440
- JR
- Thank you received: 448
25 May 2009 17:44 - 25 May 2009 17:46 #293971
by JR
Replied by JR on topic WANTED: '80 KZ750E cam chain tensioner
I bu**ered my original one last weekend and put one of these on
www.z1enterprises.com/detail.aspx?ID=370
Last edit: 25 May 2009 17:46 by JR.
- Carr_113
27 May 2009 10:30 #294390
by Carr_113
'74 Z1-A
'80 KZ750E
'80 GS750E
'81 KZ440
Replied by Carr_113 on topic WANTED: '80 KZ750E cam chain tensioner
Thanks for the suggestion, JR. I found the one I was looking for on eBay for cheap(ish), so I'll see how that works out.
'74 Z1-A
'80 KZ750E
'80 GS750E
'81 KZ440
- JR
27 May 2009 17:20 #294450
by JR
Good for you
Saw your other post in Bike Related and replied thinking your rattle might be primary chain.
- bigkaw815
27 May 2009 17:25 #294453
by bigkaw815
Replied by bigkaw815 on topic WANTED: '80 KZ750E cam chain tensioner
In my experience, all of Kawasaki's three KZ cam chain tensioner designs were flawed and will eventually bind, causing slack in your cam chain. The only solution is the APE tensioner, expensive as it is for a drilled out blank with a locknut!
- RonKZ650
- Thank you received: 240
27 May 2009 19:42 #294505
by RonKZ650
Replied by RonKZ650 on topic WANTED: '80 KZ750E cam chain tensioner
Really the tensioners were pretty reliable. I'm not all that up on the 1981 up stuff, but the 77-78 KZ650/1000 manual tensioner worked perfect every time for me at least. The 650 I ride now has 65000 miles on it and the tensioner works fine, my old original with 167,000 miles the original tensioner went around 150,000 miles and was still working but the pushrod end was all beat up and beginning to crack. Still worked fine even cracked, but I threw on a used one just because I had 10 or so laying around. The 79-80 auto type with all the bad rap I never had an inkling of problem with either. I'm rather easy on equipment though. Don't see the need to redline every shift. I've read here the tensioners can back up in their bore when running high RPMs. I never run high RPM so can't comment there.
