- Thank you received: 1
What octane should I be using ?
- Calhoun
- Hayabusa= I ride to the strip club in flip flops
These guys are car crazy.
80 IT175, 84 XL200, XT250, 95 ST1100 96 xr650l (30k miles),kz1000, KX250 97'
Last and most important 93 KX500.
- ccentralm
1982 Kawasaki KZ 750LTD. i wanted the big boy 1000, but there's like a billion of these 750 ltds running around. so what the hey!
- bountyhunter
- Thank you received: 337
I don't recall if the 1980 750 LTD is a twin or a four hole, but the 750 twins run 8.5 compression.Plummen wrote: "no reason why a stock 8.5:1 motor should need 93 octane gas."
I didn't know KZ750s had such low compression. The stock compression on the 1977 KZ650C1 is 9.5:1. Ed
- brianpclarke
To clean out carbon, do the seafoam thing where you draw it in through a vacuum line until it kills the engine. let it sit about ten minutes, then run it out. You will look like a crop duster for a while when you are riding from all the smoke coming out, usually lasts maybe 15 - 20 minutes.
How do you do this????
-Brian
1977 KZ650C
1976 Kz900 LTD
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- bountyhunter
You feed it into the intake manifold through a vacuum hose. Get the engine hot first. I used a hose with an adjustable clamp (small vise grips) and a little funnel to pour in the seafoam. I started it up and let it draw in slowly for about 30 seconds, then opened the clamp up and let it flood in which chokes out the engine but fills inside the cylinder surfaces with the cleaner. let it soak about ten minutes, close off the vacuum lines and run it until the exhaust isn't smoky anymore. It will raise a cloud of black smoke the size of your house as the carbon burns out.
- hugo
- '92 Zephyr 750
- Thank you received: 71
Higher octane does not make for a better fuel. It's got additivives to make it ignite at higher temps, so compression alone would not ignite it. It is for TRUE higher compression engines. So unless you have increased your compression. You have a timing problem.
- Thank you received: 2829
The 1980 KZ750H1 LTD is a 4 hole.
- Old Man Rock
- Thank you received: 225
Low octane for a STOCK motor I get (as designed back in 1976).... Regular (leaded) gasoline..... Smoke like a biatch. :laugh: Hell, can't even by this any longer around here.
But what about newer head/valve/seat re-builds and such... make a difference?
Way back when, motor heads where discussing where super unleaded was bad for valve seats, ate them up. Hold the same for motorcycle valve seats?
Also, here in AZ, in the fall we get the Ethanol fuels...
Wow... not I have a headache.... :S
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- bountyhunter
- JR
- Thank you received: 448
I have a 1980 kz750 E1 (4 cyclinder). The Haynes manual says compression is 9.0 : 1 and it runs just fine on whatever is cheapest at the pumps, 87 or 89 or whatever it is. Does not matter if there is 10% ethanol in it or not.
i like bountyhunters tip for how to use the seafoam and if I could find some up here I might even try it on mine
- PLUMMEN
- Thank you received: 104
id say any motor built after early 70s should be fine with unleaded fuel with stock seatsYou know, at first I was like WTF with this posting then in reviewing some the the replies and really thinking about it, this is actually a good topic...
