Anybody have tips on how to remove cylinder?
- Pro_window78
23 May 2009 13:08 #293504
by Pro_window78
Anybody have tips on how to remove cylinder? was created by Pro_window78
Hey Guy's I have a 78 kz1000, but I'm not working on that today. I just bought a 77 gs750 4 cyl sazook for my wife. it was seized so I tore it down to the jugs, but I can't seem to get them tore off. It has one reaaallly rusted piston. I was wondering if anyone has had some experience with this, This is my first engine tear down and everything looks pristine except the one cylinder. Thanks for any help!
- Thank you received: 2098
23 May 2009 13:53 - 23 May 2009 14:00 #293511
by Patton
Replied by Patton on topic Anybody have tips on how to remove cylinder?
Would apply PB Blaster or Kroil several times daily for a week if necessary to allow continuous wet soaking in hopes the rings/piston may be freed with minimal pounding on the piston. Want to avoid damaging rods. Best imo to have the piston moving inside the bore prior to attempting to separate the jugs from the cases.
Others will recommend auto transmission fluid, Marvel Mystery Oil, etc., and I seem to recall Yamaha having a specialty product for this particular application.
Will likely require an overbore and next size pistons/rings to re-use the same jugs, depending on extent of damage to the one seized bore.
Btw, any idea about how many miles are on the GS750?
Good Luck!
Good Luck!
Last edit: 23 May 2009 14:00 by Patton.
- Mark Wing
- Thank you received: 22
23 May 2009 13:54 #293512
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic Anybody have tips on how to remove cylinder?
I guess you'll need to oil down that cylinder and try again.
Mark
Mark
Yorba Linda Cal.
- bountyhunter
- Thank you received: 337
23 May 2009 17:07 #293545
by bountyhunter
Replied by bountyhunter on topic Anybody have tips on how to remove cylinder?
Kroil is the best penetrating oil I know of.
- PLUMMEN
- Thank you received: 104
23 May 2009 17:25 #293552
by PLUMMEN
Replied by PLUMMEN on topic Anybody have tips on how to remove cylinder?
take a short piece of a 2x2 board stick one end on top of center of stuck piston and start banging with a hammer,if its stuck that bad youre probably gonna need pistons anyway
- Pro_window78
24 May 2009 11:02 #293664
by Pro_window78
Replied by Pro_window78 on topic Anybody have tips on how to remove cylinder?
Got it seperated, just have one stud binding up way at the top, I will get it off!!!
- APE Jay
- Banned
- Thank you received: 58
25 May 2009 10:03 #293864
by APE Jay
Replied by APE Jay on topic Anybody have tips on how to remove cylinder?
You could have done it like they used to do the old flathead Fords. Just take all of the head nuts off and start the engine. :laugh:
- PLUMMEN
25 May 2009 18:00 #293980
by PLUMMEN
APE Jay wrote:
thats where i learned the board on top of piston trick! :laugh:You could have done it like they used to do the old flathead Fords. Just take all of the head nuts off and start the engine. :laugh:
- Pro_window78
25 May 2009 20:23 #294044
by Pro_window78
Got em off. The bottom end is stuck too, I think this bike is getting parted out. Hello ebay
