Oil plug frozen to oil pan
- Z1Rider
- Sandy
- Fly High,Tony
- Thank you received: 13
kzrider.com/index.php?option=com_kunena&...d=2&id=287450#287975
1977 KZ1000 A-1
- Thank you received: 2098
It's been a while since I have loged on. Progress on the bike has been slow but steady until last night. I tried to get the oil out of the engine only to find a hacked up oil plug nut. By the time I got done with the vise grips and the pipe wrench it got much worse the !@#$%^& wont come out, any suggestions? The oil filter spun right out but only a pint of oil came out there is still oil in the pan so I'm a little concerned about heating it.:blink:
Would heat area with propane torch, give it a couple of good whacks, and perhaps try grip-tite socket or cold chisel and hammer method tapping around the edge. Could also try filing new flats on the plug. Sometimes it helps to force (hammer) a smaller socket in place over the damaged plug for better grip. Then an impact wrench may loosen it.
If remove battery and fuel tank, with a couple of old tires for padding, may carefully lean the bike over onto its side for better access to the stuck plug.
When reassembling, a new plug is available from Z1E.
Good Luck!
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- Techhead0_3
1980 KZ750G1 LTD
- gnfreak
Normal, IL
1980 KZ1000-G1 Classic - Sold
- Z1Rider
- MFolks
- Thank you received: 540
www.browntool.com/Default.aspx?tabid=255&txtSearch=safety+wire
Here's a link to new oil plug from Z1E.
Don't know whether it comes with a new 0-ring.
Z1E Oil Plug
Good Luck!
- 76 LTD
