Clutch Release Problems 84 KZ700
- Treeman
- 1984 KZ 700 A1
1984 KZ700 A1
2005 Harley Softail Springer Classic
Palmyra, NY
- Thank you received: 2098
I replaced my clutch cable, cleaned and greased the release mechanism and have tried adjusting the clutch countless times. Each time the clutch release pops out of of its housing rendering the clutch useless. The release appears to only be installed one way with the are of the pointed downward. The clutch worked before I replaced the cable although it was hard to work and it engaged and disengaged at the outside travel of the clutch lever. Is it possible the spring behind the clutch release rod is weak or I have the release installed improperly? I was thinking of trying it with the adjustment screw screwed in rather than the 1/2 backout turn it calls for but obviously concerned want problems that could cause. Help please!
Does allowing more gap between the adjuster and clutch push rod make any difference?
Does maximizing cable slack at the handlebar whereby the adjuster barely engages the pushrod when fully squeezing the lever, make any difference?
Perhaps the pushrod is bent, scoured, or otherwise damaged so it's not freely moving back and forth between the adjuster and ball bearing.
Or maybe the ball bearing is damaged, or the spring pusher is damaged.
For possible consideration is the roller bearing style spring pusher from Z1E
Roller bearing style spring pusher
But I would first rule out other possible reasons why the oem system is failing.
Good Luck!
- gane
- Thank you received: 1
[img][/img] 1977 KZ1000A1
- Treeman
- 1984 KZ 700 A1
1984 KZ700 A1
Palmyra, NY
