Missing 2 out of 4
- jfash
19 May 2009 16:54 #292732
by jfash
Missing 2 out of 4 was created by jfash
Ive got a 81 gpz 1100 fuel injected. Leaving it sit overnite, the two outside cylinders dont fire on start up.
the plugs smell like fuel. Change plugs and the beast flashes right up. What a beautiful rumble when all are present. It will start fine all day. The next morning,same thing, only 2 and 3 are firing. Coils are new and blazing.
I put dynacoils on her.Can anyone advise me on this problem.
- MFolks
- Thank you received: 540
19 May 2009 17:00 #292734
by MFolks
Replied by MFolks on topic Missing 2 out of 4
Are you running the stock sparkplug caps? How about the sparkplug wires? The coils and related ignition devices are in a high heat environment under the tank, I'd start by replacing the plug wires and caps and go from there. Also check the primary coil wiring,As I believe it has 1/4" slide on connectors that can work loose from vibration/heat-cool cycles.
- jfash
19 May 2009 17:34 #292740
by jfash
Replied by jfash on topic Missing 2 out of 4
the dynacoils came with its own wires and caps so they are new as well.
One point though, whenever i remove the plug cap while it is running and keep it just above the plug, the cylinder fires.
this happened with the old coils and the new ones. I found that very odd
- jfash
22 May 2009 18:38 #293396
by jfash
Bump
- roy-b-boy-b
- Thank you received: 103
22 May 2009 18:41 #293397
by roy-b-boy-b
Replied by roy-b-boy-b on topic Missing 2 out of 4
My bike do that when i trailer them. I would try some spray silicone. Seems moisture condenses on the bike. Roy
- Thank you received: 2829
22 May 2009 18:49 #293398
by 650ed
Replied by 650ed on topic Missing 2 out of 4
Man your bike is talking to you. It's saying "I'm a nice bike, why don't you put a cover on me instead of leaving me exposed to the elements?"
- Thank you received: 2098
22 May 2009 20:04 #293412
by Patton
Replied by Patton on topic Missing 2 out of 4
What is voltage at #1/4 coil primary terminal? Supposed to match battery voltage.
Good Luck!
Good Luck!
- jfash
25 May 2009 10:10 #293865
by jfash
Coils are brand new, getting a nice spark, the bike is always stored inside. Can you explain the condensation and to with of my problems it referes to. Im stumped as to why the plug fires if i remove the cap and hold it slightly above the plug
25 May 2009 10:34 #293872
by 650ed
Since it seems to fire ok when you hold the cap off the plug, I would swap coils and see if the problem moves to the other 2 cylinders. If it does, this will isolate the problem to the coils /wires/or caps. Ed
25 May 2009 11:01 #293878
by Patton
Does bike have an oem ignition with igniter?
What is ohm rating of new Dyna coils, and does ohm rating match the old coils?
Good Luck!
Good Luck!
