white smoke
- concrete kawboy
19 May 2009 15:07 #292711
by concrete kawboy
white smoke was created by concrete kawboy
i have a 1980 kz1000. the bike has white smoke coming out of the exhaust when it is warm. it has pod filters and a kerker 4-1 header with no baffles. i dont know if it has been jetted or not. also it has the low emissions head and the valve cover is leaking exhaust around the #4 emission port. could the smoking just be that the carbs need to be jetted, or do you think it is rings/ valves. the bike has 30,000 miles on it. it runs pretty good, but it seems to stumble on hard excelleration and at high rpms. hope someone has some info for me. thanx.
- KOOL RYDER
- KZ 650B2 / KZ 1000E
19 May 2009 15:30 #292713
by KOOL RYDER
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
Replied by KOOL RYDER on topic white smoke
My KZ 1000 79 always puffs white smoke like BOB Maley did when I start it afer it has been sitting for awhile and under hard acceleration.
Also when it rains.
I would check the spark plug on #4 to see what it can tell you. Is it oily, or carbonized?
You may need to replace your exhaust crush ghasket on the #4 pipe.
Anyone else?
Also when it rains.
Anyone else?
1978 KZ650B
1979 KZ1000ST
- brianrae33
19 May 2009 17:48 #292745
by brianrae33
1982 kz1000ltd
Replied by brianrae33 on topic white smoke
i'd definitely check your jets as far as rthe stumbling goes..
1982 kz1000ltd
- harm
- Tom
- Thank you received: 13
19 May 2009 17:56 #292748
by harm
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
Replied by harm on topic white smoke
I would also check the compression and valve clearances.
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
