Late throttle response!
- DMR
I'm not to good at diagnosing this stuff so any help is greatly appreciated. let me know if I need to provide any more details. Thanks.
1980 KZ650
-Vance and Hines exhaust
Duluth, MN
- athlonwirez
1978 LTD Partial Restoration in Process. (Do not have orginal exhaust)
- MFolks
- Thank you received: 540
- athlonwirez
- DMR
Is the spark good at all four sparkplugs? Have the sparkplug caps been checked or replaced? Plugs properly gapped? Ignition coils primary and secondary wiring in good shape? Good fuel flow to the carbs?
spark plugs are all good
caps are fine
plugs properly gapped
wiring is in good shape
fuel flow should be fine
Once I get on the throttle and I get over that little bump, the engine runs perfectly fine.
1980 KZ650
Duluth, MN
- Kingchiefa
- To each thier own.
caps are fine
I was having that same problem on my 79 KZ 1000, is it slow to take off from 1st gear?? Are you almost all the way off the clutch when it finally starts to roll?
1979 KZ1000 ltd b3 Currently in Troy, PA. Hope to some of you on the road.
- DMR
caps are fine
It takes off fine from 1st, but then when I let off the clutch and give it gas, it takes a second for it to respond and pick up. Also, when I shift higher up in the rpms, it isn't as noticeable.
1980 KZ650
Duluth, MN
- Pro_window78
- jfash
Find out what range of rpms you are having your hesitation in.
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- gane
[img][/img] 1977 KZ1000A1
- larrycavan
- Visitor
On a few, it was simply over full on oil and the excess got blow into the airbox and saturated the air filter. If it's a stock airbox setup. Check the filter.
Had a guy come in one time with a bike that flat out died when you gave it anything more than a little throttle. Removing the gloves he had stored under the seat so the airbox opening wasn't 3/4 plugged off cured that one
Point is this. Check the obvious before anything else...Stuff happens.... :woohoo:
