Looking for a KZ1000 cylinder head for my 79 MKII
- fullbore
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- Jack
- Thank you received: 7
The 73-80 heads WILL fit your MKll bottom end but only 79 & 80 cylinder heads will match exactly in terms of appearance.The older heads had different castings & rocker covers than the MKll.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- fullbore
Checked compression and 2,3,4 wern't to spec? Decided it was time to pull head.
What I found was both valves bent on #3 and hadn't been seating in awhile. Put the head on the bench and filled chambers with fuel of course #3 ran right intake and exhaust. #2 & 4 emptied in about 10 seconds. #1 held for quite awhile.
What's odd is I have most likely been running it that way for awhile and it seemed to run good. Started right up no backfiring or popping.
Can't wait to ride it when it's running on all four.
2 cam hold down block bolts are stripped on #1. I can probably tap a little deeper and get a longer bolt but I would just as soon have a head with no issues.
- timebomb33
- davel
Finding a head with no issues may be an issue. Sounds like you have a good rebuildable head. Helicoiling bolt holes in these heads is more the rule than exception; especially cam cap threads in MKII heads. There are many postings on this site about that exact problem. Expect any used head you are likely to find to have some damage...stripped bolts, missing cam bearing caps, broken fins, "hi perf" port job, etc.
Don't be discouraged by a set of helicoils. If done properly, the head will be as good or better than new.
- KZ_Rage
- Kentucky Bourbon Barrel Ale
- Thank you received: 19
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
- Tony
- Thank you received: 13
time-serts
You could have your head redone and have them repair the bolt holes at the same time.
It's interesting, when I changed head gasket on my mk2 last year I had a bent valve as well. It also ran good.
- fullbore
I have a few buggered spark plug holes but only in the top of the thread. I'll run a tap through those to clean the threads also.
Got the stock exhaust off to the plater to be re-chromed. I figured I'm going to stay as close to stock as possible on this bike because they are not very easy to find.
I have located a another complete motor for my other MKII project it's out of an 80 classic and as I recall they are also MKII motors? Can anyone confirm that? (KZT00GE-XXXXX)
I should be able to throw together a pretty decent run around with the parts I got left. Maybe a "rat" bike project?
- Thank you received: 2098
I'm going to do a little extra work on the head and put studs in for the cam caps. I think it's better than the stock setup and definately stronger.
Got the stock exhaust off to the plater to be re-chromed. I figured I'm going to stay as close to stock as possible on this bike because they are not very easy to find....
put studs in for the cam caps -- if not already considered, would be mindful of possible clearance issue between stud end and valve cover.
buggered spark plug holes -- if not removing head before re-tapping, would consider the reverse tap (special tool) that chases thread beginning from the deep end.
stock exhaust off to the plater to be re-chromed -- where was a plater located that's willing to re-chrome exhaust headers or mufflers? Had about given up on this because the carbon inside reportedly ruined the chemicals in the chroming tanks involved. Said it's impossible to first remove the carbon. Maybe a radiator shop boiling before re-chroming?
Good Luck!
