Need a crankshaft man............
- chiefgto
- War was just a game we played when we were kids.
18 May 2009 18:57 #292492
by chiefgto
1979 LTD1000 B3 Chassis.
1980 LTD1000 Engine.
MTC 1075 10.5-1 pistons, 3 angle valve job with mild port and polish. V&H 4 into 1 pipe. Mikuni BS34 Carbs. Dyna 2000 ignition.
Need a crankshaft man............ was created by chiefgto
Any recommendations? Also, I plan on powdercoating the engine cases. Is that a bad idea?
- timebomb33
- Thank you received: 10
18 May 2009 19:57 #292502
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Need a crankshaft man............
if they do it right you can powdercoat no problem but if they don't it can be an absolute nightmare i wouldn't myself i have seen all kindas of problems bolt holes filled with powder oil passages plugged gasket surfaces covered all kinds of good stuff like that i'd probably just stick to paint myself. as for your other question, what the hell man
- APE Jay
- Banned
- Thank you received: 58
- Old Man Rock
- Thank you received: 225
19 May 2009 04:53 #292578
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Need a crankshaft man............
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- larrycavan
- Visitor
19 May 2009 06:14 #292590
by larrycavan
Replied by larrycavan on topic Need a crankshaft man............
Have you considered a good epoxy paint on the cases?
- otakar
19 May 2009 06:31 #292594
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Need a crankshaft man............
Powder coat is a bad idea for engines. The coating is quite thick and will hold in too much heat. Use KG GunKote, or Polane. GunKote is very tin film and Polane you can regulate the thickness.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- chiefgto
19 May 2009 16:46 #292728
by chiefgto
Replied by chiefgto on topic Need a crankshaft man............
What about just leaving the cases bare after blasting? A nice rough finish on the outside of the cases should help to dissipate heat. But, are they susceptible to corrosion?
