Oil pressure
  • STOCKS3
  • STOCKS3's Avatar Topic Author
Oil pressure
07 Mar 2006 19:36
#29228
I was told that most Kz's run at about 3 to 5 psi oil pressure.
That said any one know where in fine a good low oil ressure gauge.
Post edited by: STOCKS3, at: 2006/03/07 22:41
Post edited by: STOCKS3, at: 2006/03/07 22:43
  • donthekawguy
  • donthekawguy's Avatar
Re: Oil pressure
07 Mar 2006 21:38
#29273
I think this was brought up a week or so ago. As soon as someone reads it who knows they will help.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • steell
  • steell's Avatar
Re: Oil pressure
07 Mar 2006 21:55
#29277
the 3-5 psi oil pressure figure is for the 900/1000/1100 motors as they are the ones that use roller bearing cranks. The 250/400/440/550/650/750 motors use plain bearings and have a much higher oil pressure (30-40 psi).
  • 1973Z
  • 1973Z's Avatar
Re: Oil pressure
08 Mar 2006 10:47
#29369
You can order a nice gauge made by MC Enterprises and costing around $60 from Dennis Kirk or your local dealer. You have to wrap teflon tape around the threads, instructions are included. The factory manual for my 1973 Z1 recommends 3 pounds of pressure at 3,000 rpms at an oil temperature of 60 degrees Centigrade, which means you'll have to get an oil temperature gauge, too, and they sell one at www.americanclassix.com for about $50.
  • kawtoy
  • kawtoy's Avatar
Re: Oil pressure
08 Mar 2006 10:55
#29370
Remember, 60 degrees C = 140 degrees F
1.8(C)+32=F
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
  • TuffyToo
  • TuffyToo's Avatar
Re: Oil pressure
08 Mar 2006 14:13
#29421
I bought one from BubsRacing.com The link is below. They have real nice Marshall liquid filled gauges at a good price.
www.bubsracing.com/catParts.jsp?cat=Gauges&sub=fuel
