many problems need lotsa help....
- Bek82
- Hounddog09er
- KZ 1100 spectre
Braden
1998 kx80
1982 Kz1100 D1 Spectre
- fixer5000
- Thank you received: 5
1978 kz650b pretty much stock
massachusetts
- Thank you received: 2829
- pburnhamb
www.bt-andf.com/index.php
i just got a set to get off a completely rounded off wheel lug on my car and it worked extremely well...well worth $25. and they are guranteed to work, says it right on the box. i suggest using it with a breaker bar or socket wrench, not an impact wrench.
thats if you are stripping the heads of the bolts not the threads. use KROIL like 650ed said in either case, that stuff is magic
1978 kz650b (810, 750 head)
1976 kz900
1977 xs650
- pburnhamb
1976 kz900
1977 xs650
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- JR
- Thank you received: 448
- Bek82
- JR
Does anyone know if disconnecting the MC will not make the plugs fire?
MC = Master Cylinder ?
Should'nt prevent the plugs firing ...........but then I'm not familiar with the twins.
On the other hand mine wont fire unless the clutch lever is pulled in as there is a safety switch built in. Again I dont know if the twin had this feature
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
one of those handheld impact drivers can save a lot of aggrivation with stuck fasteners
Ya, i agree with you there. I used the handheld impact drivers on my z1 900 and it worked like a charm.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- Yojymbo!
