Top End Job
- mseems
- 1982 KZ 550 A3
- Thank you received: 2098
Good Luck!
- Thank you received: 2829
- bountyhunter
- Thank you received: 337
sounds pretty good to me.Hello, can someone please give me an overview of a top end job on a kz550 a3? My compression is about 150 on all four cylinders. Is that bad?
sounds like the petcock is either not cutting off (if it is vacuum type) or you are leaving it on. Also, carbs may need the float needles/seats worked on to seal properly.Bike smells like gas pretty bad after riding.
- mseems
- 1982 KZ 550 A3
Thanks
- bountyhunter
Pipes are blue too like its running too rich.
Blue = lean
Pipe turns blue because of higher temps.
Although, most single wall exhaust pipes do eventually turn blue at the first turn near the exhaust port even if the mix is correct.
- mseems
- 1982 KZ 550 A3
- Bicycle Lee
and why is blueing on the pipe bad??? There's people who go nuts over that stuff
It sounds like a carb issue to me, unless the petcock is dumping fuel somewhere.
1978 KZ1000 police
- KOOL RYDER
- KZ 650B2 / KZ 1000E
Like the guys have suggested, check the easy stuff first:
Make sure the petcock is in working order, fuel line, vaccume line, check for correct type spark plugs. Is the bike running on all the cylinders, easy to check by spraying the exhaust headers with a spray bottle and H2O. If the water turns to steam upon contact then your fine, if not then you are down on a cylinder ect...
Do you have clear tubes running from the overflow nipples on your carbs? If not and you have nipples, then you should add some.
I am new to riding, but these items have saved me a pile of cash over the last 2 years.
KR
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
