Speedo Cable Help
- mseems
- 1982 KZ 550 A3
16 May 2009 21:39 #291797
by mseems
Speedo Cable Help was created by mseems
Hello everyone! Can someone tell me the proper procedures to replace the speedo cable? I recently replaced mine and it worked good for about a day then it broke off at the end by the wheel. I thought the cable was pre-lubed so I didn't lube it. I am about to order a new one but don't want the same thing to happen. Also I recently replaced my stock handlebars with superbike bars. My clutch cable is a little long but seems to shift fine. Is it necessary to replace the cable if there is a big bend in it even if it is working fine? The stock cable is 52.5" and I was thinking of ordering one that is 50" or one that is 48.5". Any advice is much appreciated!
- JMKZHI
- Thank you received: 48
17 May 2009 00:21 #291818
by JMKZHI
Replied by JMKZHI on topic Speedo Cable Help
There's no need to replace the clutch cable - it'll still work just fine. Mine's been too long for a couple of years now.
- mseems
- 1982 KZ 550 A3
17 May 2009 08:43 #291895
by mseems
Replied by mseems on topic Speedo Cable Help
cool thanks for the info
- mseems
- 1982 KZ 550 A3
17 May 2009 15:40 #291953
by mseems
How about the speedo? Any reason why a new one would break after using it for just a day?
- GPz550D1
- Thank you received: 22
17 May 2009 17:33 - 17 May 2009 17:34 #292000
by GPz550D1
1981 KZ550-D1
Replied by GPz550D1 on topic Speedo Cable Help
mseems wrote:
I would just chalk it up as a defective cable. Kind of hard to mess up the intallation of one. Just have to make sure each end is fully seated, but I am sure you did that. Probably not your fault. I don't know if you used a Kawasaki cable or aftermarket. I would use the genuine Kawasaki part if it could be found.
Robert
Robert
1981 KZ550-D1
Last edit: 17 May 2009 17:34 by GPz550D1.
- gane
- Thank you received: 1
17 May 2009 18:03 #292064
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Speedo Cable Help
Cables in general need be routed to avoid severe bends. since distance for speedo cable is limited by routing or changed forks, check speedo drive for placement. would check drive , proper location usually allows for exit of cable parallel to ground or slightly down. luck g
- GPz550D1
17 May 2009 18:58 #292190
by GPz550D1
1981 KZ550-D1
mseems wrote:
You can check the speedometer adapter on the wheel that the cable screws into and see if it might have seized up. If you can, turn the tire a litle and see if it is turning inside. That would mess up a new cable also!
Robert
Robert
1981 KZ550-D1
- mseems
- 1982 KZ 550 A3
17 May 2009 19:38 #292205
by mseems
Cool thanks for the replies. I will check the speedo gear to see if its turning with the wheel.
