cam identification
- DoubleDub
- Visitor
18 May 2009 12:14 #292437
by DoubleDub
Replied by DoubleDub on topic cam identification
Thanks!
- modprod
22 May 2009 20:17 - 22 May 2009 20:19 #293418
by modprod
Replied by modprod on topic cam identification
otakar wrote:
Well this was the most common spot in the later years but "certainly not" the only spot that was used. RC often used a spot on the cam sprocket flange and Norris ground a flat and engraved an ID on the shaft, among other spots
Aftermarket cams are always marked on the end of the cam at one end. There will be a stamp which will include the manufacturer and grind #. Each maker has there own grind #. What are the markings on the end flat of the cams?
Last edit: 22 May 2009 20:19 by modprod.
