Backfire and exhaust leak!
- nickcycle
15 May 2009 20:13 #291552
by nickcycle
Backfire and exhaust leak! was created by nickcycle
My 1979 kz1000 has had exhaust issues since I got it. I cannot seem to get the headers to seal properly aagainst the head using the copper gaskets. The collars tighten all the way to the head and the pipes are still not very tight, and I can hear (and sometimes see) exhaust leaking out. There HAS to be a better way than these gaskets? or use two per cyl.? And when deccelerating I get major backfire. I am running straight pipes and pods, so I know SOME backfire is normal, but this is ridiculous! HELP!
Thanks!
Thanks!
- Thank you received: 2098
15 May 2009 20:25 - 15 May 2009 20:27 #291555
by Patton
Replied by Patton on topic Backfire and exhaust leak!
Perhaps split collars are the wrong size (meaning not quite long enough) for these particular headers. Some headers have thinner flanges at the end which require slightly longer collars. Did the split collars come packaged with a brand new exhaust system?
Wouldn't use double copper gaskets.
Let's figure out exactly what's wrong.
Thicker gaskets are available as a last resort, but really shouldn't be necessary.
Good Luck!
Good Luck!
Last edit: 15 May 2009 20:27 by Patton.
- nickcycle
16 May 2009 05:38 #291615
by nickcycle
Replied by nickcycle on topic Backfire and exhaust leak!
The split collars came with th e bike, no idea if they're stock/ aftermarket. Where might i find slightly LONGER collars if I need em?
- Old Man Rock
- Thank you received: 225
16 May 2009 06:34 #291623
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Backfire and exhaust leak!
Contact Jeff @ Z1 for further detail in length available....
Redline has them as well but until you measure yours, hard to say...
www.redlinecycle.com/flanges.html
Z1 also has thicker sized copper exhaust gaskets....
www.z1enterprises.com/detail.aspx?ID=196
NOTE: One side of your copper ring is beveled... The flat side goes to the head exhaust port, the beveled side goes to the exhaust manifold pipe... You may want to confirm
"running straight pipes and pods"... Was this configuration on there previously or is this something new to your ride you've installed?
If new, then you'll most probably need to re-jet your carbs....
OMR
This usually denotes too lean carb setting/jetting....when decelerating I get major backfire
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- trianglelaguna
- Thank you received: 235
16 May 2009 06:38 #291624
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic Backfire and exhaust leak!
on a diffrent note but same theme.....i just spent some time getting down with my exhuast issues ....once my bike had fallen off the center stand sofly forward onto the pipes....only later while fixing a previous exh issue did i find that when freed up the pipes had a new tweek at the ports.....i found that one of my top header flanges needed a "pop" with my palm or a tap with a rubber mallet to make it a good linning up to the copper gaskt/o-ring before the flanges and coller went on.....as for your dilema my split collers are also drawn tight and i start to bottom out the collers "just" as the nuts get tight....suzuki exh gskts are thicker and z1-e has em the look silver and have materiel emmbedded.........i might find an extra split coller to measure length on a stock one today and repost......good luck you'll get it right......unburned gas from seperate fuel mixture/jetting.. issues gets burned in the header and goes "BANG" or POPS imo.....best of luck...peace craig
1976 KZ900
2003 ZX12R
2007 FZ1000
- gane
- Thank you received: 1
16 May 2009 18:27 #291758
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Backfire and exhaust leak!
Nick, random thoughts. first, the exhaust 1/2 moons (collets )are directional. the skinney end goes into the head. with the turned over lips fitting to the fitting plates.2nd, some after market pipes incorperated additional spacers which were used in conjunction with stock collets which may be missing. once pipes are introduced to head sealing areas should get snug long before running out of threads, even with pre-crushed exhaust gaskets. 3rd, if the easy fix is to double up w/ exh gaskets, why not? additional gaskets won't restrict flow, and straight pipes wouldn't care any way. exhaust leaks along with being annoying can lead to burnt valves. hope this helps,G
16 May 2009 19:44 #291783
by Patton
nickcycle wrote:
Another possibility is that the existing split collars had for whatever reason been ground shorter.
This could have conceiveably resulted from an attempt to wrongfully assemble them by fitting with the flanged end toward the engine instead of correctly positioned with the flanged end nested inside the exhaust clamp.
I seems to me that a single gasket is preferable because it allows the flanged end of the exhaust pipe to rest inside the exhaust port on the engine head whereby the system may better self-align and be better supported at the head area without depending solely on the studs and clamp. Not to mention the extra difficulty of holding not one but two gaskets in position during reassembly.
As they say in army training, with your right hand hold part A, with your left hand hold part B, with your other hand . . . :laugh:
Good Luck!
Good Luck!
- nickcycle
17 May 2009 12:44 #291920
by nickcycle
Thanks ALL! I have tried most of these already, doubling gaskets, etc, even made my OWN gasket out of 20 guage copper sheet, a donut to fill the entire exhaust ports, but no luck. Think I just have to try to get some longer split-collars. And the bike came to me with the pods and open 4 into 1 system, but there's no guarantee it was re-jetted to match. I'll hafta dig into that one too.
THANKS
THANKS
- nickcycle
17 May 2009 15:13 #291948
by nickcycle
SUCCESS!! This time I used 2 gaskets, stuck em together with exhaust putty, and used the putty to stick em in the head. NO LEAKS, no popping on decel, exhaust note even sounds better, like a Ferrari!!! And TAKE YOUR TIME, make sure everything is lined up. Jiggle the end of the muffler a bit as you tighten the collars, and everything should be kosher.
