Need recommendation for helicoil insert kit
- nob_1100
Thanks all for your comments.
83 1100 Ltd
- kano
- Not Another Bloody Limey!
This is the kit I purchased:
www.toolsqwik.com/storefrontprofiles/Del...c=145637&i=234717501
just ordered from them too,
needed m8 125 for exhaust studs.
time inserts are highly recommended by ppl here.
NEW TIME-SERT M8 X 1.25 Metric Thread Repair Kit
cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&s...IT&item=290306298463
NEW BIG-SERT By TIME-SERT M8 X 1.25 Thread Repair Kit
cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&s...IT&item=300303962276
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
Other than a drill, tap, and a flathead screwdriver, they require no special installation tools. At about $10 for qty 10, you can't beat the price.
I've had very good luck with these, replacing cam cap bolts after the heli's came out and disintegrated.
West Linn, OR
- Tony
- Thank you received: 13
I was going to buy a Heli Coil kit, but when I was disassembling the head I discovered that one of the cam cap bolts already had been treated with a Heli Coil insert. It wasn't holding the bolt tight. It was probably the fault of the person who did the work, but I decided to order a Time Sert kit just to be safe.
If it has already been helicoiled and that hole is bad you will probably need big-serts.
Her's a link.
bigserts
- nob_1100
83 1100 Ltd
- nob_1100
The first problem I encountered was that I couldn't locate a suitable handle. I went to three different local automotive stores to look for a tap handle but none carried it. I tried various size sockets but nothing fit perfectly to the square head of the tap and drill bit. At the end, I had to use a pair of vice pliers to grab each Time Sert tool. The second problem was that in some threads I wanted to repair, various engine parts got in the way of the electric drill's chuck. Again, I had to resort to the pliers.
The third problem was very frustrating. I put back the cylinder head, and was tightening the cam cap bolts. Of course one of the bolt threads got stripped. As many of you know, the cam cap bolt threads are recessed; the thread does not start until 1/2 inch or so below the cylinder head surface. But the Time Sert insert has a lip/flange at the top, which is a tad larger than the recess hole. So I had to enlarge the recess in order to screw in the insert. I got lucky again :woohoo: because this thread was located directly under the bike frame, so my drill could not reach there. I didn't want to remove the head just for this, so I spent the next grueling hour fiddling with the vice pliers in the tight spot.
The lesson learned is that I need to get a tap handle. But above all, I need to put Time Serts in all M6 threads (cam cap bolts, valve cover bolts, engine covers) while parts are off the motor.
Oh, I'm happy to report that I didn't have to get a Big Sert kit to restore the thread that had been repaired previously with a regular coil insert.
83 1100 Ltd
- MFolks
- Thank you received: 540
- KawiConvert
- Thank you received: 4
For things like the holes for covers and such I'd used them in a heartbeat. The thing to watch out for though is how big do you have to drill and tap to put in any of these inserts. If there isn't much material the helicoils may be the only way to go.
Heres a link to the keyed inserts.
www.mcmaster.com/#key-locking-inserts
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- nob_1100
Sears has a pretty good selection of tap handles and the machinist's supply stores do too. Even Harbor Freight has some cheapies.
Sears, of course. Why didn't I think of that... Thanks.
83 1100 Ltd
- KawiConvert
